First and foremost; Welcome to FTE: Believe 61 thru 66 will work only issue would be the holes for the earlier model hood side emblems. In the event the 65 hood is from a Custom Cab there are holes for the side trim pieces, not sure how the holes would line up with the 62 hood emblem, with any luck, may only need to fill in couple holes?>? Imagine other member's will be chiming in to clarify. Again welcome to FTE!
Make sure you get the bolts that attach the hood as well. The early hoods use fine threaded bolts and the later models use coarse threaded ones or vice versa as its been a couple years since I had mine off. I found out the hard way when I bought a 1966 hood for my 1963 pickup and had to locate some.
