Schematics
Old Oct 3, 2017 | 07:49 AM
jcormiea's Avatar
jcormiea
Schematics
Does anyone have exploded schematics of the engine compartment of an '83 F100? Trying to sort out what I've got in there but I am not a mechanic, yet. I have the Haynes manual but I can't seem to use it to ID components.
Old Oct 3, 2017 | 09:32 AM
Hound Dog Lew's Avatar
Hound Dog Lew
I do not, but if you want to post a clear picture with the items you need identified marked A, B, C, etc., I and I'm sure other folks would be happy to help.
Old Oct 3, 2017 | 10:22 AM
jcormiea's Avatar
jcormiea
OK. I'll take and post pics when I get home. Thanks didn't even think of that
Old Oct 3, 2017 | 11:52 AM
grumpin's Avatar
grumpin
Here's some basics.
Engines - ???Gary's Garagemahal
Old Oct 3, 2017 | 12:01 PM
jcormiea's Avatar
jcormiea
I've got all of those things figured out as well as starter, solenoid, alternator... I can be more specific with pictures but it is the more advanced things I can't ID. I found an engine schematic on Gary's site under Engine-300 Six but all of the parts are labelled with part numbers and he does not have the name list up yet. Is there a collection of what those part numbers would be identified as? Just trying to gather as much info about my P/U as possible before I dig deeper through the rust.
Old Oct 3, 2017 | 04:44 PM
jcormiea's Avatar
jcormiea
These are a few things I am unsure about.
Old Oct 3, 2017 | 04:45 PM
jcormiea's Avatar
jcormiea
I suppose that white box next to the Master Cylinder too as I don't know the official name.
Old Oct 3, 2017 | 04:53 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
DuraSpark Ignition Module.
A = Alternator Regulator.
B = Distributor Vacuum Valve.
C = I don't know which part you're pointing to. Arrow ends just before the left inner fender apron.
Note: There are several different types of modules, several different types of the dizzy valves.
Old Oct 3, 2017 | 06:03 PM
Franklin2's Avatar
Franklin2
B should be located on your emissions sticker on the radiator. You might want to post a picture of that sticker.
Old Oct 3, 2017 | 08:15 PM
FuzzFace2's Avatar
FuzzFace2
Is C pointing to the brake pressure differential valve?
Dave ----
Old Oct 3, 2017 | 11:58 PM
grumpin's Avatar
grumpin
Great job! Keep it up.
Old Oct 4, 2017 | 06:58 AM
jcormiea's Avatar
jcormiea
C is pointing to the piston looking object next to the inner fender. I thought it might be part of the brake system? is the white box to the lower right of the master cylinder the power control module?
Old Oct 4, 2017 | 07:11 AM
FuzzFace2's Avatar
FuzzFace2
I don't see what it is you are talking about, maybe the shock?
Try and take a better picture of it.
That box is the ignition box or ignition module.
Dave - - - -
Old Oct 4, 2017 | 07:35 AM
ctubutis's Avatar
ctubutis
I think he might be asking about the steering shaft.
Old Oct 4, 2017 | 08:19 AM
KULTULZ's Avatar
KULTULZ
Post
Must be the RABS Valve.
IGN MODULE
