95 PSD, Auto Transmission, Manual Locking Hubs, 4wd shift levert on the floor:
Needed 4wd this weekend but floor shifter did not "feel" right and dash light indicator was not giving me any feedback on position. When I got home where I could take a closer look, I found that the metal shift shaft had come off of the pin on the shift linkage. I cannot seem to get the shaft to slip back over the pin. However, I was very tentative with it for fear of doing greater damage to the linkage if I applied too much force. Looking for some advice on getting that shaft back on without tearing up something else in the process.
I had to replace mine last year. They get corrosion and can get hars to shoft. If you let it go too far, theyll freeze up and crack when you try it. Easy to replace.
