rear under bumper lights
Old Oct 2, 2017 | 08:30 AM
Fortworthian's Avatar
Fortworthian
From time to time, i have a need for lighting to the rear of my truck. Has anyone mounted a light bar, or lights under rear bumper and wired to upfitter switches so that the lights can be used without placing truck in reverse? I've seen lights mounted like this in the past, but i personally have never installed. I need uses for the upfitters switches and this seems to be a great use.
wife opening ranch gates and working on something behind truck main uses.
Old Oct 2, 2017 | 08:47 AM
jergle's Avatar
jergle
I actually started working on that very thing this weekend. Ordered two 4 inch LED lights from amazon for about $13. Took me a while to figure out where to mount since I didn't want to drill any holes if I could help it. There are 2 holes in the back of the receiver hitch where the safety chains go, so I fashioned a mount to use those holes from a 3 inch angle bracket. Have the lights mounted, just need to run the wire to the upfitter wires in the front. Should definitely come in handy.
Old Oct 2, 2017 | 09:16 AM
OneTon350's Avatar
OneTon350
I just drilled and tapped into the hitch receiver and ran a wire
from one of the upfitter switches. It was pretty easy.
Old Oct 2, 2017 | 09:21 AM
nuctrooper's Avatar
nuctrooper
Heres a pic of mine. Flush mount in the bumper. Have a relay with a tap off the reverse lights feeding the NC contacts, and an upfitter feeding the trigger and NO contacts. Thus they come on automatically whenever I go into reverse, or I can throw an upfitter to bring them on manually.
Old Oct 2, 2017 | 09:31 AM
Fortworthian
Looks great all, keep them coming.
Old Oct 2, 2017 | 09:48 AM
Ralls's Avatar
Ralls
I'm liking this idea with the upfitter wired in for constant. Education on the NC and NO contacts you speak of please
Old Oct 2, 2017 | 10:43 AM
nuctrooper's Avatar
nuctrooper
(Pic borrowed from the web)
Look for a standard 12V relay. It needs to be a SPDT (Single Pole Double Throw). Hook power to the light to pin 30. Hook ground from light to chassis and a ground from pin 86 to chassis. Wire a tap from the reverse light (trailer connector wire bundle) to pin 87a. This will turn on the reverse LEDs whenever the truck's reverse lights are on. Run a single wire feed from your desired upfitter relay output under the hood and follow the trucks wire bundle all the way back to the rear drivers corner where you installed the relay. Wire this feed into both pin 85 and pin 87 (effectively jumper them together). now, when you throw the upfitter, the relay shifts and powers the lights from the upfitter feed. When you turn the upfitter off, the relay shifts back and powers the lights from the reverse light feed.
Last edited by nuctrooper; Oct 3, 2017 at 09:11 AM. Reason: Edited to correct a typo on the coil ground.
Old Oct 2, 2017 | 03:19 PM
Mgjfam's Avatar
Mgjfam
Subscribed and watching---great ideas so far.
Old Oct 2, 2017 | 03:36 PM
matrix311's Avatar
matrix311
I'm thinking about buying this from ZROADZ. It would make for a super easy install, no drilling required and it uses existing bolts in the rear bumper to mount. You can mount two 6" or 8" led light bars to these rear bumper brackets.
Here is just the bracket itself. I would buy this and likely use MIC Tuning 8" single row LED light bars. They are about $37 for 2 of them from Amazon.
Rear Bumper LED Mounts | ZROADZ
Or if you want the ZROADZ kit, they offer it with the bracket and their own branded lights here. Comes with everything needed to do the install including wiring.
Rear Bumper LED Mounting Kit Combo with 2 LED Light Bars and Wiring Harness | ZROADZ
If your looking for something even more simple, ZROADZ offers a hitch mount mount with two 3" cubes. My least favorite.
Universal Hitch Step Kit with Two 3? LED Lights ? 2 1/2? Hitch Size | ZROADZ
Old Oct 2, 2017 | 03:53 PM
cficare's Avatar
cficare
Are those two outboard hitch receivers used for a motorcycle lift?
Old Oct 2, 2017 | 07:15 PM
nuctrooper's Avatar
nuctrooper
Don't want to hijack the thread, but they're for a rear porch for my truck camper. Love having it back there. Of course, could also haul a motorcycle rack, tailgate grill, luggage, etc. Also, it still lets me tow while I have the step installed.
Old Oct 2, 2017 | 08:00 PM
burgy's Avatar
burgy
Thats some nice work!
Old Oct 3, 2017 | 12:36 AM
Faceplant409's Avatar
Faceplant409
NUC-
Brilliant sir!
Old Oct 3, 2017 | 01:19 AM
MagicMtnDan's Avatar
MagicMtnDan
FWIW, a couple weekend ago I installed 2 Rigid Dually lights under the rear bumper. Of course you'll note that I have a 2017 Ford Raptor not a SD so the rear bumpers are not the same.
The left one is Amber (for off roading in the dust) and right one is White. I'm going to use a couple of the Upfitter Switches to control them separately as I don't want to automatically blind everyone behind the truck when I put it into Reverse.
http://www.fordraptorforum.com/attac...2017-09-16.jpg
There's a hole in the bottom of the bumper perfectly placed between the exhaust and hitch frame. The hardest part is getting the washers and nut on the bolt as it's challenging for large hands. Also note that angle settings - left/right & up/down - are much easier to set before you bolt it in place.
Old Oct 3, 2017 | 07:46 AM
grege's Avatar
grege
Look for a standard 12V relay. It needs to be a SPDT (Single Pole Double Throw). Hook power to the light to pin 30. Hook ground from light to chassis and a ground from pin 86 to chassis. Wire a tap from the reverse light (trailer connector wire bundle) to pin 87a. This will turn on the reverse LEDs whenever the truck's reverse lights are on. Run a single wire feed from your desired upfitter relay output under the hood and follow the trucks wire bundle all the way back to the rear drivers corner where you installed the relay. Wire this feed into both pin 86 and pin 87 (effectively jumper them together). now, when you throw the upfitter, the relay shifts and powers the lights from the upfitter feed. When you turn the upfitter off, the relay shifts back and powers the lights from the reverse light feed.
I'm liking this idea. First, where/how did you mount your relay? Second, you might want to edit your post. You have pin 86 going to ground and getting power from the upfitter switch. Oops.
Greg
