changing gears
Old Oct 3, 2017 | 02:31 PM
ultraranger's Avatar
ultraranger
Originally Posted by meangreen92
I think the Mustang T5s even had a .63 overdrive for a year or two!
That was in the '93 Cobra/Ford Motorsport Z-spec T-5.
The Cobra T-5 1st gear ratio was 2.95:1, compared to the 5.0L Mustang GT T-5 which had a 3.35:1 1st gear ratio.
Old Oct 4, 2017 | 08:00 PM
YooperUno's Avatar
YooperUno
Just trying to get better gas mileage
Hi guys sorry I didn't include everything
It has a 4 speed tranny, 351M engine with a mild cam and a 4bbl 600 Edelbrock carb, I have 33" tires on the truck. What I'm trying to achieve a little better gas mileage I wont b towing nothing a very little hauling stuff in the back maybe a 4wheeler at times on a trailor. I have all the power I need now with the 3.50 gears that's why I was wondering if I dropped it down to around the 3.00 gears I wont lose to much power on the highway at 65mph I'm running 2600 rpm's. I'm gonna do the rear axle first and c what happens and if I like it I can do the front axle I have donner axles with pigs in it to swap out if I done like it I can throw the other differentials back in it
Oh and btw thks for all the info and I will let yous know how it goes if I do it but winter is coming upon us now pretty quick and I wont b able to run it on the highway with the way they throw salt on it kind of bits to live in the North because of that
Old Oct 4, 2017 | 08:03 PM
YooperUno's Avatar
YooperUno
Originally Posted by boingk
Shouldn't be an issue. Setting up a differential can be a bit of an art, though, so make sure you a) really know what you're doing or b) pay someone who does to do the job.
With standard size tyres and a 3.00 rear you will top out somewhere north of 100mph if you have the power to get there.
Cheers - boingk
boingk I have someone on line that will change the gears that knows what their doing tks for the reply
Old Oct 4, 2017 | 08:07 PM
YooperUno's Avatar
YooperUno
What some people use for advice.
Tks for the chart 77&79F250
Old Oct 4, 2017 | 08:12 PM
YooperUno's Avatar
YooperUno
Originally Posted by 78Broncoinpieces
before you swap out the rear gears, are there 3.00 gears available for your front axle?????
in the correct rotation?
I will look and c what is available for the truck before I do it for sure but tks 78Broncoinpieces for the reminder
iMetal
22
Apr 13, 2018 04:16 PM
Daplumma
Jan 26, 2007 07:11 PM
Cowboy34
17
May 17, 2006 01:46 PM
Bigdaddy29384
Jan 30, 2005 08:45 AM
maddmatt13
Sep 27, 2003 04:34 AM
