Sponsored by: Real Truck
Rim size help
Old Oct 1, 2017 | 04:44 PM
3rdfordtruck's Avatar
3rdfordtruck
Rim size help
Hi guys
Looking for a some help
Will 18” rims from 2006 F350 on a 2017 F350
Will 18” rims from 2012 f250 fit on 2006 F350
Old Oct 3, 2017 | 10:02 AM
WE3ZS's Avatar
WE3ZS
Originally Posted by 3rdfordtruck
Hi guys
Yes, as long as the '17 F-350 is a SRW truck of course.
Yes, again as long as the F-350 is a SRW. The big rim change happened with the changeover to coil front springs on the 4X4 rigs in model year '05. Earlier trucks wanting to run later rims require spacers to fit properly, and later trucks wanting to run early rims will have brake clearance issues as the minimum wheel diameter went to 17" in '05 due to larger brakes, nearly all pre '05 wheels were 16". The exception to that rule is if dealing with the rare-ish '04 (only year for them) Super Duty Harley, Lariat, K-R and SVT 18" wheels, but they will stick out almost 2" farther than stock wheels on a late model truck due to the different geometry.
Old Oct 3, 2017 | 10:53 AM
3rdfordtruck
Huge Thanks
Thank you both for your responses. Very helpful.
Old Oct 3, 2017 | 01:15 PM
Colorado350's Avatar
Colorado350
I use a website called: myboltpattern.com. You can find out yours and/or compare another vehicle to see if the rims are capable.
Mark VII
Dec 11, 2014 06:50 AM
CRF1966
Jan 7, 2008 11:44 AM
twcracker
Oct 4, 2005 10:07 AM
Shawn90yj
Jun 17, 2005 06:10 PM
6.0king
Mar 5, 2005 12:16 AM
