FORESCAN HELP
Old Oct 1, 2017 | 09:51 AM
scotty16's Avatar
scotty16
FORESCAN HELP
Hello folks, thanks for all the great posts. I tried to program the 12 v power outlets to stay on (didn't work) then stay on for 4 hours per the spreadsheet using forscan and OBDink Bluetooth. After several attempts it did not work. My problem is I changed the code and cannot remember the original code to change it back. I am also fairly stupid and did not create a back-up. So the code I changed was:
POWER POINT DISABLE TIMEOUT-BCM- 726-39-01 I changed the first four digits in the string from ???? to 3870 per the spread sheet. I need to know what the first four digits in the string are per the factory: ****-x1xx-xxxx
Ben L
6.7L Power Stroke Diesel
Jul 19, 2019 10:39 AM
sandyc
May 30, 2018 12:21 PM
MikeyO'Brien
Sep 20, 2015 07:46 PM
Ratpack
Mar 19, 2007 12:32 PM
