PCV problems
Old Sep 27, 2017 | 09:58 PM
Commostud's Avatar
Commostud
PCV problems
Hello,
I have a new PCV installed on my truck 1990 460 with 5 speed. My idle is 900 to 1100 rpms and when I put a finger over the pcv my rpms drop down to normal levels. It did the same with the old one too. I got the pcv from Napa.
My pcv has won serious sucking power going through it. I use a lot of oil as well.
Any ideas what or if anything I can do.
Old Sep 28, 2017 | 01:53 PM
rla2005's Avatar
rla2005
Where is the other end of the crankcase air intake hose plugged into? It should go to a small filter in the bottom of the air filter box.
Old Sep 28, 2017 | 08:35 PM
ChRoNo16's Avatar
ChRoNo16
I think you have more issues involved. How many miles are on the engine?
Old Sep 28, 2017 | 08:52 PM
Commostud's Avatar
Commostud
My crankcase is connected to the air box. There is no oil in air cleaner. I can take the pvc out of the valve cover and put my finger on the pcv intake and the rpms will drop to normal level.
Old Sep 28, 2017 | 09:05 PM
Commostud's Avatar
Commostud
I have 112k on engine. I have new/rebuilt heads on the engine. I use between 1 and 2 quarts of oil every dual tank fill up. It randomly sends a puff of smoke out the tail pipe. It usually does this when I hammer it or let off the gas. It also does a strange thing like valve rattling (at least that's how I describe it) and send a puff or two out the tail pipe. I am thinking of pulling the intake and changing the intake gasket to see if that fixes that sound.
I had my cat removed when I got a new muffler.
I don't have any scored bores or lips on the cylinders when I changed the heads. It runs well and has decent power. I get 12 to 13 mpg. But just trying to figure out things to improve my old truck. I do this because I really like my truck and my wife utterly hates it. Lol.
Old Sep 28, 2017 | 10:00 PM
88XLTLariat's Avatar
88XLTLariat
The smoke and "valve rattling" is most likely from worn valve stem seals.
Old Sep 28, 2017 | 10:13 PM
Commostud's Avatar
Commostud
I just paid 800 bucks in July to rebuild my heads. So it should not be that.
The valve rattle sound does not happen all the time. Sometimes it happens when I hammer it or have a heavy load on it. But it does not happen all the time either.
Old Sep 29, 2017 | 12:47 AM
KULTULZ's Avatar
KULTULZ
Post
You mean PCV Valve correct? The actual valve is only a part of a complete system. You pull the valve with engine running and put your thumb over the valve inlet?
If the idle drops when you block-off the valve it is indicating either the actual valve is bad/bad design/not calibrated properly for the application or is drawing outside air somewhere before the valve (bad valve grommet/major gasket and/or seal leak in the engine).
The increased RPM is as a result of a vacuum leak, leaning out mixture/fuel curve.
Old Sep 29, 2017 | 01:04 AM
Commostud's Avatar
Commostud
Yes the pcv valve. I put a new one on and it still has this problem. It is not leaking anywhere else that I know of. I got it from Napa auto parts and it did not help.
Old Sep 29, 2017 | 01:28 AM
KULTULZ's Avatar
KULTULZ
Aftermarket parts quality is questionable. MOTORCRAFT parts quality has become questionable. But I would rather have the MOTORCRAFT valve rather that some cheap import.
That valve is a controlled orifice and the spring calibrated to the exact application. Does the valve fit tightly in the grommet?
MOTORCRAFT parts are available on the net cheap. I don't understand going to these auto stores. NAPA used to be quality. It no longer is. It's a crap shoot when you open the box.
Simply put, you have a lean fuel mixture. This will also cause the valve rattling @ load. If the valve is sucking excess fumes/oil from the crankcase, the fuel mixture will also become leaned out.
Old Sep 29, 2017 | 05:02 AM
'89F2urd's Avatar
'89F2urd
The "valve rattle" is ping, and you don't want to allow it to occur.
The pcv system is a vacuum leak, no way around it, although the computer is designed to at the very least be aware of the metered (at least "supposed" metered) air coming through the pcv.
If you're using that much oil, you likely have bad rings, and should start with a compression test before replacing anything else. That much oil getting burned could also explain your ping, but testing for vac leaks is first and foremost.
Compression test, check for vac leaks.
Old Sep 29, 2017 | 07:39 AM
rla2005's Avatar
rla2005
As the others have stated the PCV is a controlled vacuum leak or sorts. I believe your test is masking the real root cause.
Based on your symptoms (high idle RPM & oil consumption and pinging) I would suspect an intake manifold leak from the under side. Oil in the air/fuel mixture will cause pinging. Second on my list is leaking rings. A compression test is definitely in order and a lot easier than replacing intake manifold gaskets.
RadioControlGuy85
Mar 2, 2019 02:08 PM
joel79ford
Jun 13, 2012 08:37 PM
TexasGuy001
17
Jun 26, 2009 11:25 AM
amorgeron
Dec 26, 2006 10:04 AM
savage250
Feb 12, 2005 09:21 PM
