Aerostar Ford Aerostar
Front diff leaking 4wd
Old Sep 27, 2017 | 11:45 AM
davran's Avatar
davran
All,
The front diff is leaking like a sieve, seemingly where the axle tube goes into the diff housing, and I can't see any damage. Any ideas on where to start?
Thanks, Dave.
Aerostard 4wd leaking front diff
Old Sep 27, 2017 | 12:06 PM
93nighthawk's Avatar
93nighthawk
On that side there is a breather valve near the top, center-ish, I would check that to see if it blew out. There is no seal for the shaft tube going into the dif, but there is a miniscule chance the there is a crack there, and the only thing you can do is JB weld or replace.
Old Sep 27, 2017 | 12:58 PM
davran's Avatar
davran
Ok, thanks.
Old Sep 27, 2017 | 01:23 PM
96_4wdr's Avatar
96_4wdr
100% full timing running diff with 30% of engine HP driving it.
Breather plug can also plug, causing pressure inside diff, pushes lube out.
Also switch to Mobil 1 75w90 hypoid lube like the rear diff.
The ATF Ford puts in is too thin and has far less antiwear antifriction additive. Causes high temps and thins ATF further causing leaks.
Been running M1 150,000 + miles
Old Sep 27, 2017 | 06:49 PM
xlt4wd90's Avatar
xlt4wd90
When I replaced the ATF in the front axle with 75W90 Mobil 1, the stuff overheated and spewed out of the vent tube. I think the gear lube is just too thick for that little axle, creating all the excess heat.
Old Sep 28, 2017 | 08:28 AM
93nighthawk
Here is a TSB from Ford on this issue, it is obsolete from Ford, but they moved the vent to the top of the cover so it was higher up:
TSB
98-23-3
  • AXLE - FRONT - FRONT DRIVE AXLE FLUID LEAK FROM VENT
[************]Publication Date: NOVEMBER 6, 1998[/COLOR]
LIGHT TRUCK:
1990-1997 AEROSTAR
ISSUE:
Front drive axle fluid may leak out of the vent under some driving modes on some vehicles. This may be caused by the design of the vent.
ACTION:
Install a revised front axle cover assembly which incorporates a baffled vent and plug the original vent. The service procedure is detailed in the Instruction Sheet included in the Axle Cover and Baffle Kit.
The Axle Cover and Baffle Kit (F79Z-4033-AA) includes the following:
  • One (1) Baffled Cover
  • One (1) Vent Hose
  • One (1) Plug (for original vent)
  • One (1) Instruction Sheet
PART NUMBERPART NAME
F79Z-4033-AAAxle Cover And Baffle Kit
Old Sep 28, 2017 | 11:20 AM
xlt4wd90's Avatar
xlt4wd90
I can't tell from what you posted, but is the kit supposed to be installed some place other than the axle tube? Like maybe on top of the axle housing? Is there enough clearance?
Old Sep 28, 2017 | 01:38 PM
93nighthawk
Fixed it, sometime copy/paste go wacky.
Old Sep 28, 2017 | 01:39 PM
93nighthawk
It looks like if you want, you can modify you original cover to move the vent upward and plug the current vent. I don't have any pics of the new cover to show.
Old Sep 29, 2017 | 03:37 PM
davran's Avatar
davran
Excellent info: thank you.
briangelc
Sep 26, 2012 03:40 PM
Sailor182
Nov 12, 2011 01:29 PM
acm05fsu
1997 - 2003 F150
May 16, 2010 08:22 PM
NW-F350
Sep 10, 2007 06:51 PM
vze2sgxa
Feb 3, 2006 06:17 PM
