rough idle
Old Sep 9, 2003 | 01:12 PM
Herm's Avatar
Herm
rough idle
1989 E350 with 460 fule injected motor 60,000 miles (Fleetwood Jamboree Motorhome). I replaced plugs, wires, rotor, cap, air filter, PCV, 5000 miles ago last year when I bought it - used all OEM parts. Idled very smooth until last week after I returned from a 200 mile trip - now idle is very rough - can hear slight pops/misses at exhaust.
Also noticed exhaust pipe has black soot (not sure if this is new)
Would appreciate any ideas/thoughts/possibilities on what is causing rough idle or suggestions for further troubleshooting - I'm a pretty advanced home mechanic but this engine is new to me.
THANKS - Herm
Old Sep 9, 2003 | 08:46 PM
powerfull's Avatar
powerfull
rough idle
hey my dad has the same problem he said its his o2 sensor in the intake but were to lazy to fix it
Old Sep 9, 2003 | 11:31 PM
c_rossman's Avatar
c_rossman
rough idle
Check the vacuum line going to the MAP sensor, if it is leaking, the motor will run rich because of less manifold vacuum.
Old Sep 9, 2003 | 11:33 PM
c_rossman's Avatar
c_rossman
rough idle
The computer ignores the 02 sensor at 3/4 and above throttle positions. IF it runs good WOT but not part it maybe the O2
Old Sep 10, 2003 | 01:35 PM
f350bronco's Avatar
f350bronco
rough idle
If it the problem started suddenly, I would look for vacuum leaks. Cracked or lose hoses are a very good place to start.
We are assuming the the engine otherwise runs fine.
John
Old Sep 10, 2003 | 04:08 PM
Herm's Avatar
Herm
rough idle
Thanks everyone - I'll check out your suggestions and post the results next week - Herm
