92 I6fuel pump acting up
Old Sep 9, 2003 | 11:10 AM
pancake's Avatar
pancake
it is a 92 f150 and has the I6 it has duel tanks and yesterday it started acting up like i got water in the gas...in the rear tank(the one i use normally bc my front tank leaks)so i switched over to the front tank i filled the rear tank up and have put 3 bottles of drygas in so far and it wont clear it up...
the truck idles as smoothe as can be when on the rear tank but the minute i even lightly touch the gas it coughs spits sneezes and swears at me,oh and it bogs down too!i switch back to the front tank and it is as good as can be again even under load...so i think my fuel pump is on its way out ...
i considered the possibility that the fuel filter is plugged but the fuel from both tanks go thru the same filter so it should act up on both tanks which it doesnt
i dont know how to check if i have a plugged line
help?!
Old Sep 9, 2003 | 11:23 AM
LxMan1's Avatar
LxMan1
Sounds like the low pressure pump in the rear tank has died. You might check there first.
Jimmy
Old Sep 10, 2003 | 09:23 AM
cdrmckinneybb63's Avatar
cdrmckinneybb63
Thumbs up 92 I6fuel pump acting up
hello there,
i feel that your pump is going out also and you need to replace it, good luck, gene,
Old Sep 12, 2003 | 08:56 AM
pancake's Avatar
pancake
ive got a question...><<>
now i have been trying to run on the rear tank as much as i can to try and burn some of the gas in the tank up so when i do drop that tank it isnt as heavy and messy(splashing around)
i have noticed that if i fluctuate the gas pedal...up and down almost like you would with getting a carbuerated vehicle that hadnt run in a while started after a little while of that and also after the truck does a little bit ofwhat seems like the surging/bogging that normally happens during heavy rain it just ..takes right off like there is no problem ...,and this happens from every stop just about am i an idiot or could it possibly be whatever type of pickup tube is in there on the pump may be clogged and once the fuel gets past the blockage it is fine(i am just making this up as i go along i am not sure of anything ) this didnt start happeneing until i ran the tank real low and has happened ever since then and who knows what kind of garbage and gunk is at the bottom of the tank
Old Sep 12, 2003 | 11:45 AM
LxMan1's Avatar
LxMan1
The pump is at the bottom of the pick-up. There is a strainer under the pump. but they rarely clog up.
Jimmy
