Rear axle tag
Old Sep 21, 2017 | 02:22 PM
jaleus's Avatar
jaleus
Rear axle tag
The truck is a 1974 f100 302 C4 2wd. I know the axle is a 9 inch. But not sure what the tag is telling me. It reads.......
WDM-AC 3HE
3.25 9 331A
Based on my reading here on the site, it's an open rear end, at least it acts that way.
Is the gear ratio 3.25?
Thanks for any help.
Old Sep 21, 2017 | 03:45 PM
gittinwidit's Avatar
gittinwidit
Yes. If posi it would have an "L" in the middle of the 3.25 somewhere. Think between 3 and decimal? Or it's between decimal and 2. One or other, can't remember.
Old Sep 21, 2017 | 04:25 PM
jaleus's Avatar
jaleus
​​​​​regarding the gear ratio.......this truck is basically the toy, pulls a Jon boat from time to time, maybe a 16 foot utility trailer, sack Crete and plywood from the big box every once in a while. It's comfortable at 70ish mph on the hwy, turning 2800-3000 rpm. What might I expect in a rpm reduction with a 3.00? I don't think my towing use would be overly affected.
Old Sep 22, 2017 | 07:33 AM
gittinwidit
Here's a gear calculator to mess with. 3.25 is my favorite all around gear.
Gear Ratio Calculator
Old Sep 27, 2017 | 09:24 AM
jaleus's Avatar
jaleus
So I'm still working towards limited slip and 3.00 gearing in this rear end, have been studying to best arm myself in digging through candidates for another center section at the pic-n-pull as an option. The documentation showed my axles to be 28 spline. I found a U tube video that said the exterior end of the axles, the hub, are cast different for the 28 and 31 spline axles.......kind of a "D" shape for 28 and three dimples or holes for 31, stated this holds true throughout the years.........yes I know, take many things from the web with a grain of salt (although I'm on it asking this question) and that Ford had oddities that might be rooted in transitions they where making.
Question is, is there any outward indication of spline count on the axles??
What info i did find showed my axles should be 31, book said they should be 28, and I pulled one and they are 28. Is the casting shape info bad info?? Here's another site that talks about end shape but says it's only certain before '71. www.metropartsmarket.com/rearend/measures.html
As always, thanks again.
My axle end, 28 spline.
Old Sep 27, 2017 | 09:38 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
WDM-AC 3HE 3.25 9 331A
WDM-AC = Ford 9" rear axle; 3.25-1; no Limited Slip; 28 spline axleshafts (D3TZ-4234-K).
3HE = Assembled the 5th week (E) of August (H), 1973 (3).
Old Sep 27, 2017 | 03:39 PM
jaleus's Avatar
jaleus
Thanks again.
8086ford
Feb 17, 2016 12:13 PM
Buzz44
Jun 22, 2012 12:13 PM
fordbii
Mar 13, 2004 10:44 AM
DeeBee
Sep 12, 2003 09:53 AM
ewellman
Jul 25, 2003 11:35 PM
