2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Dash lights
Old Sep 18, 2017 | 08:57 PM
Steffyhat's Avatar
Steffyhat
Dash lights
2007 Lincoln Navigator.
136,000 miles
Oil pressure L/H needle light and battery charge L/H needle light flash on and off all the time.
Replaced alternator a few months ago, battery is new, and and recently replaced canister purge valve because engine light came on along with traction control light and the code given was for the evap system and auto zone recommended that part.
Engine light is now off and so is the traction control but these needle lights still flash.
Any ideas?
Old Dec 4, 2023 | 08:47 AM
Salina's Avatar
Salina
1st Gear
136,000 miles
Any ideas?
I have the same problem, have you been given any info about this?
Old Dec 27, 2023 | 02:22 PM
gwcloud's Avatar
gwcloud
Hi, I had a similar problem with my 2007 Navigator.
Here is what I learned: There is a tiny led light bulb that lights up each gauge needle. The bulbs have 4 connectors and are soldered to the circuit board.
You could buy a used instrument panel from a wrecking yard online for $60 -$150 and have it programed to your car at a dealership. My dealership would have done that for about $350. Your car will not start or run without programing the different panel to your car.
I found a small company in Missouri that would solder new bulbs into my circuit board for about $50. I pay postage to and from their shop.
I used youtube to learn how to solder to a circuit board and get a part number for the bulbs. I think I bought 10 bulbs for about $10.
Good luck,
Richard
tobyzach101
1997 - 2003 F150
May 15, 2018 01:04 PM
tobyzach101
All Things Towing
May 15, 2018 12:43 PM
davehaynes
Jul 23, 2011 12:53 PM
agg_bagg
Apr 7, 2010 01:13 AM
stevenn1
Dec 31, 2006 05:32 PM
