Charge wire question
Old Sep 16, 2017 | 03:21 PM
J ballan's Avatar
J ballan
Hello everybody, I have a 12' enclosed cargo trailer and I wanted some better lighting in the inside. So I mounted two LED lights in the inside and a battery on the hitch like a camper would have. Here's my question, I'd like it to charge while I'm driving so I added a 10ga wire from the positive post straight to the trailer wiring plug. Is this correct? Wouldn't the 10ga wire get hot or melt if the trailer battery was dead needing lots of amps? Doesn't really seem like there is enough room in the plug for a larger wire. Thanks for the help.
Old Sep 16, 2017 | 04:27 PM
Chuck's First Ford's Avatar
Chuck's First Ford
most use a 20 amp fuse at tow vehicle...
and 10 gauge will handle 20 amps easy..
a dead battery should be changed by a 120 volt battery charger.. NOT a 12 volt car/truck.. good way to kill an alternator.
once a 12 volt battery is drained below 10 volts.. some of its life is GONE. and will never recover fully.
Education is important when altering electrical systems.
Old Sep 16, 2017 | 05:07 PM
J ballan's Avatar
J ballan
Sounds like I'm good then. Thanks for the quick reply. In a perfect world it would get charged up with a charger when the voltage gets too low but I just wanted to be safe because I'm sure it's going to happen sooner or later. I'm running a deep cycle dry cell type battery so that should help with the charge/discharge cycling.
Old Sep 16, 2017 | 11:27 PM
seventyseven250's Avatar
seventyseven250
Absolutely put a fuse on that charging circuit. And when possible charge from "shore" power as soon as possible after any deep discharge and before and after long periods of storage.
Old Sep 17, 2017 | 09:11 AM
J ballan's Avatar
J ballan
Yes for sure, 30amp should be a good match for a 10ga wire hey?
Old Sep 17, 2017 | 09:20 AM
RV_Tech's Avatar
RV_Tech
That's fine. The charge lead is also already fused under the hood of your truck. There's really no way you can deliver more amperage to your trailer than that fuse will pass.
Steve
carl2591
Feb 22, 2016 06:44 PM
Sycostang67
All Things Towing
28
Jul 17, 2014 07:11 AM
Fred H
Electrical Systems/Wiring
Sep 17, 2007 02:29 PM
ZonaNavyStar
All Things Towing
Aug 28, 2007 07:02 AM
Cheleri
All Things Towing
Jun 24, 2004 09:50 PM
