I have found the problem
Old Sep 8, 2003 | 11:04 PM
alabamabuddog's Avatar
alabamabuddog
This is what I did to my motor tring to clean the throttle body and intake
I dont think anything else is hurt but its getting a rebuild anyway. Its the # 8 Piston and rod , valve must have been wide open. Advice to anyone doing this : remove the plugs and spin the motor first!
https://www.ford-trucks.com/user_gal...humbnail.php?&
Old Sep 9, 2003 | 07:39 PM
Trail Rider II's Avatar
Trail Rider II
Did you read the can of cleaner? "Run a high idle." all that cleaner going into any cylinder could burn or knock o hole in the piston.
Old Sep 9, 2003 | 08:54 PM
alabamabuddog
OK I admit I wasnt thinking. I removed the throttle body to clean it then started wqorking on this pile of deposits at the bottom where the throttle body bolts up. I just wasnt thinking.
