ranger bed trailer
this truck started out as being a project, had 180k miles on it, found out it needed a transmission (no 1gear 4r44e auto) needed a windshield and a few other minor things. body was decent so i thought id pull the bed to make a trailer from it later, put a simple wood flatbed on it, sell it and look for something diffrent. got a few offers, mostly people wanting to trade. one day i took it out for a spin, came home and was thinking about playing out in a field with it. so i go out, start drifting and somehow, someway when i went to turn left and do a powerslide it got a grip and i rolled it onto its roof. motor was still running with it upside down. i went and got a tractor to get it back on its wheels. top of cab was crushed in and had body damage to the right side. it sat for about a month, during which my (very nice) 92 was stolen and i needed another running truck. picked up a rough 94 2.3 longbed, it needed a few things but it was stuff i could take from the rolled 97, cab mounts, fuel tank , rear bumper, ect. after i took off what i needed, i thought id remove the frame from the trans crossmember back and make a trailer. the bed on the 94 wasnt as good as the bed on the 97 so i had already transfered the bed over, but the 94 bed is still good enough to be a trailer. following is a list of picture links. its almost done now, just want to put a toolbox on the front for a saw and gear, give it a little more tounge weight.
the beginning: 1997 3.0 automatic 2wd longbed xlt: ($500)
truck stripped down after rollover, looks like a roadster:
ready to take the sawzall to the frame:
back frame with axle, almost balanced, cut frame right behind trans crossmember:
notched and bent in front frame rails, slid in a 3x3 square steel tube for a tounge, a heavy peice of angle iron as a crossmember and welded together, lincoln electrode arc welder used:
primer grey, let it sit over a week like this:
oddly enough i needed a trailer and this wasnt done yet, so still in primer and not really ready but useable, i bolted down a 3/4 sheet of plywood with eyebolts and did what i needed to do. some magnetic lights on the frame and away it went to pick up a new stove and fridge:
painted frame black, added coil helpers to axle just like i have my other rangers. theres room betweed top of coil and frame so it rides the same, only comes into play when enough weight has compressed stock susupention.:
and bed back on, debating on paint, im going to make my 94 ranger a blue/silver two-tone, not sure if i want to do this trailer to match or make it allis-chalmers orange to my 1942 "C". still going to add a truck box on front of frame for a saw or other gear:
i'll add more pictures later, right now this is where the project is, think its turned out pretty good. i thought about having a surge brake coupler on it hooked ut to the drum brakes on rear axle but but im not sure it would really work all that well with such a light trailer, laoded with wood the tractor would pull it and wouldnt be going very fast.
https://www.flickr.com/photos/154582078@N03/39417545351/
https://www.flickr.com/photos/154582078@N03/39387515512/
I picked it up already mostly done and towable for $125.00. I did have to go over some of the welds, as they were pi$$ poor. It needed some things, and a friend of mine was scraping his old farm truck at about the same time, so I got the rear bumper, both tail lights, bed liner, tailgate cables and topper before it went to the junk yard. I had a pair of 10" wide aluminum wheels with 31x10.5 tires mounted on them sitting in the barn, so I replaced the mis-matched and weather checked tires with them, and bought an un-used aluminum box off Craigslist for $80.00 for the front. Some wouldn't pull these type of trailers, but for about $200 bucks out of pocket, I have a pretty (in my opinion) decent hillbilly enclosed trailer.
just weighed mine today, since trailer licence fees for non-commercial trailers are based on weight of trailer, i took off everything i could to make it weigh as little as possible. no side racks or cap, no tailgate, no toolbox or rear bumper, and i took off my 235/15 tires on the 15x8 steel rims and put on some skinny 13" rims/tires. i even tiik the brake drums off of the ranger axle when i changed tires. i considered buying a "trailer axle" to save even more weight but thats $100 that i dont think would be worth the licence fee reduction. plus id be replacing a 3,000 pound rated axle for a 2,000 pound axle. even if i really would be ok with a 2,000 pound axle, its nice to know i have plenty of "overloading" reserve with the stock 7.5 ranger rear end. weight as i "stripped" it down to was 748 pounds. no doubt id be over 800 with bumper, brake drums, bigger tires, tailgate & toolbox. sure, i only saved a few bucks to be in the 700-800 pound range, but every bit helps. and i can fix a few things while its all apart. (like how the toolbox wasnt quite level when the trailer bed was)
