Gear oil types
Old Sep 13, 2017 | 06:08 PM
bill-d-c's Avatar
bill-d-c
Gear oil types
I recently bought a 93 F250 4X4, 5-speed with the 460. It doesn't have a manual with it, could you guys tell me what both front and rear diffs take for gear oil, as well as the transfer case and transmission? Thanks.
Old Sep 13, 2017 | 06:37 PM
wtroger's Avatar
wtroger
Transmission and tc use ATF. The rear will use 75-140 look on the tags to see if wants synthetic. Front will 75-90w
Old Sep 13, 2017 | 06:43 PM
bill-d-c's Avatar
bill-d-c
Thanks. The guy I bought it from said it uses 90wt from front to rear. I didn't think that sounded right. I know my 97 uses ATF in the TC. It's an auto so wasn't sure on a 5-speed.
Old Sep 13, 2017 | 06:55 PM
bill-d-c's Avatar
bill-d-c
One more question, do they recommend over filling these 5-speeds by a quart, like the Dodges of the same year?
Old Sep 14, 2017 | 11:19 AM
bill-d-c's Avatar
bill-d-c
Mercon 3 is what I've been told to use, but all I can find locally is Mercon V. Does that matter?
Old Sep 14, 2017 | 01:02 PM
josiewales's Avatar
josiewales
Spoiler alert: My '88 with the 5-spd manual had 80/90 wt in it from the PO when I bought it with 153K mi on it. That ruined it, I was told, when I took it to the shop. It started leaking oil so bad and it was making BAD noises at 10K later I had to replace it. It needed ATF. That's in the owners manual.
Old Sep 14, 2017 | 01:09 PM
bill-d-c's Avatar
bill-d-c
I wish I had an owners manual. The parts store guy swore it should hold 90wt. I'm convinced it holds Mercon, just trying to figure out if Mercon V will work and if I should overfill it.
Old Sep 14, 2017 | 01:25 PM
wtroger's Avatar
wtroger
Dextron III and Mercon III are the same thing. Mercon V wont hurt anything. All Adding the extra Qt to the 5 speed does is quiet gear roll over noise. To add it you have to pull the shifter. Do not put 90wt in it. For one thing you can not shift them in cold weather.
Old Sep 14, 2017 | 01:37 PM
exranger06's Avatar
exranger06
There is no such thing as Mercon III. There's just regular Mercon and Mercon V. (Technically there are a few more different types of Mercon, but I won't get into that here). Ford originally specified regular Mercon for that transmission. Regular Mercon is the same thing as Dexron III. Dexron is a registered trademark of GM and Mercon is a registered trademark of Ford. Ford and GM have different names for the same fluid. That's why bottles will say "Dexron III/Mercon" or "Dex III/Merc" or "Dex/Merc" for short. You can easily find bottles of "Dexron III/Mercon" at any auto parts store, but Mercon V will work as well.
Old Sep 14, 2017 | 02:33 PM
bill-d-c's Avatar
bill-d-c
Thanks guys, that is the information I was looking for..
BigBlocker0248
Feb 20, 2016 09:35 PM
xjvince
Mar 29, 2014 12:44 PM
MOOKIEX4
May 22, 2013 10:31 PM
brianlambert
Jul 6, 2009 09:22 PM
Stangboy12
Jul 12, 2004 07:29 AM
