1996 F350 Centurion Value
Old Sep 12, 2017 | 06:35 PM
4x484150's Avatar
4x484150
Hi guys,
I found a wicked nice truck for sale, and was wondering what yall thought of the cost to buy it. The seller is asking $24,000. Anything in particular I should ask the seller as well?
Here are some specs on it:
1996 F350 Extended Crew Cab
4x4, 7.3 auto 172,000 miles
Old Sep 12, 2017 | 07:30 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Way overpriced Alan.I'm afraid she's not worth half that anymore.If it had 72k instead of 172k miles,I could see half that asking price easy enough.
Old Sep 12, 2017 | 07:39 PM
4x484150's Avatar
4x484150
See, that's what I thought. I was figuring even 15,000 would be too much. Its a nice truck ill give him that, but its still just a truck. The guy seems pretty adamant about his price. I guess if he says no to a much lower price, then I'll walk away.
Old Sep 12, 2017 | 07:41 PM
phoskins's Avatar
phoskins
Originally Posted by 4x484150
Hi guys,
It is a beautiful truck! The seller is awfully proud of it.... For a price like that, it should be flawlessly maintained with excellent documentation to back it up, & half the miles. I doubt it cost much more than that when brand new. Centurions are known for problems where seams were welded. It should also be 100% RUST FREE. Crawl underneath & look carefully for rust. The radiator core support should be in perfect condition. The 7.3 core supports are becoming very difficult to find, & the labor to swap one is very time-consuming. The frame needs to be carefully inspected, it's at least 18" longer than any stock Ford frame, meaning it was spliced somehow. With 172k miles, I wouldn't consider anything over $12,000 unless the drivetrain can be 100% warranteed for at least another 100k. This is a risky purchase, no matter how you slice it, especially considering anything could go wrong with it right after buying it, & Diesels are expensive to maintain/repair. It's also guaranteed to be a b*tch to park in small/crowded parking lots.
Not to mention, good luck getting financing on a 21-yr. old 'customized' truck with 172k miles....
Old Sep 12, 2017 | 07:53 PM
4x484150's Avatar
4x484150
I don't think the seller has all the documentation, but I will ask.
I have done some research, and saw a few examples of how the roof can have peeling paint and rust. I should be getting some pics of the roof and underside tomorrow.
I agree, buying any vehicle 20 year old or older can bite you in the rear. I was there as a teenager
That's part of the reason of wanting second opinions on price. 12k sounds a hell of a lot better than 24k for that approval process.
10 char...
Old Sep 12, 2017 | 07:58 PM
White 97 xlt's Avatar
White 97 xlt
Personally, I would have one question of the seller... Have you lost your friggin mind????? As I walked very fast off his property to get back to a sane world!!!
Old Sep 12, 2017 | 08:06 PM
FORDF250HDXLT
You should always buy outright if possible,have the money to back up the loan,if you do have great credit,where you can borrow cheaper than removing your money from investments that are making more,or continue saving until you can buy outright.This is ideal.Anything short of this,is living outside your means.
A bank probably isn't going to loan you money against such an old truck.If you need to borrow to buy it,you cant afford it.
If you don't care,then you'll probably need a personal loan.However now your going to buy against something not nearly worth it's value (even if you get it for 10k) and borrowing at a much too high of an interest rate,against something your already upside down with.Now after the loans term is fulfilled,combined with the interest payed,your left with a truck valued for far less than you payed and your several thousands out and now in need of a newer truck.
There isn't much good about buying this one.I would pass.His asking price is far too high for what you get.If you have 8k in cash(and your retirement fund is already maxed or goal met for the year)he accepts and you can buy it outright with no loan and you won't miss the money,then that's one thing.
Old Sep 12, 2017 | 08:17 PM
4x484150's Avatar
4x484150
Definitely makes sense to buy outright. And no, I don't have that much saved up. Ill still see about getting the info, and if he will drop the price significantly. But I seriously doubt he will. So end result will probably be walking from it.
Old Sep 16, 2020 | 01:18 PM
Beis's Avatar
Beis
3rd Gear
I know this is an old thread, so I apologize up front. But is this truck still for sale? Do you by chance still have the owner's contact info? Thank you in advance!
-Ryan
timbersteel
Jul 8, 2017 09:18 PM
81f-150
Feb 28, 2016 05:01 PM
Njmyers
Feb 1, 2016 06:32 PM
bluemtn95ford
22
Mar 12, 2013 02:52 PM
kjf-250
Jul 12, 2009 06:08 AM
