Sponsored by: Real Truck
Need engine
Old Sep 10, 2017 | 05:27 PM
pigeonblood's Avatar
pigeonblood
Need engine
Think I asked this once...but lost post...where can i get a reasonably priced 6.0 turbo engine...powerstroke
Old Sep 10, 2017 | 05:57 PM
Pocketlint's Avatar
Pocketlint
You'd need to define what you believe a reasonable price is. If your looking for a used engine, then your budget is really going to dictate what kind of an engine your going to able to get.
What is wrong with your current 6.0 engine? Is it rebuildable? If the block is toast and other internal parts then your going to have to figure out what your budget is to acquire a rebuilt engine. There are lots of shops/people offering a rebuilt engines at a cheap price, but your dont know what kind of parts they have put in to make the engine cheap, there are engines out there that are 10k and up that have cheap parts in them, then there are engines that have the correct Ford/Navistar parts in them that are out there that may cost you 10k.
Your going to need to have a budget of what you want to spend, and then a fudge budget in case anything pops up. There are lots of places like Jasper engines etc out there that sell rebuilt, I have no idea what their rebuilds are like, but like anything you need to do your homework on who your buying the engine from, how and what type of parts they rebuilt the engine with and what the cost will be and what type of warranty will they back it with not to mention cost of putting it in unless you plan to do that yourself.
You could look for a wrecked truck that was in a collision and still has the running an intact engine in it, and then take it have it looked at and if all is well put it in. It's never cheap to replace a diesel engine and the parts from Ford Navistar arent cheap but you dont want to buy one with some crap china parts that are going to blow up two weeks, two months or two years down the road
The more information you can share the better responses you will get, if your engine is totally toast, your going to get hit with a core charge if it really bad, if it isnt you can use yours to get the core charge back. Have you looked into doing a rebuild? Rebuilds arent cheap but it would give you the opition to do some bulletproofing to make it last longer
Old Sep 10, 2017 | 07:55 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Here's your last thread:
https://www.ford-trucks.com/forums/1...an-engine.html
This for used engines:
http://car-part.com/
There's a place about 10 miles up the road from me with a dozen+ in stock, ranging from sub-100k Grade A to 200k+ wrecks to try to use as a core. There are a TON of 6.0s across the country listed.
If you want to not gamble on a straight used, Ashville is well known around here for remans:
http://www.ashevilleengine.com/
Old Sep 10, 2017 | 08:01 PM
530ktmpilot's Avatar
530ktmpilot
Ashville gets very good reviews on here and powerstroke.org
Amish Ford
Sep 18, 2019 06:42 PM
BalootheBronco
20
Jan 3, 2016 07:28 PM
Daveyj
Feb 22, 2011 07:19 PM
Jbsqared
Jan 26, 2005 11:53 AM
trentmh
Aug 27, 2004 02:39 PM
