Best Truck/MPG for Towing
My pics are only a snapshot
But the numbers are real... even if it was a perfect moment. And that alone is impressive... At least to me it is.
If somebody would have told me... I would have said that he or she is crazy.
And to get these numbers required a focus and "special circumstances" of hardly no traffic (so that no one is in front of me or behind - due to the way I had to drive to max out MPG).
Originally Posted by homepcmd
both were snapshots after I parked and includes a couple of miles "city driving" to the parking garage from my highway exit.
There's no way I would get these numbers from a 2-ton vehicle in the date range you specify. But I can get it with a 2016 Ford - with their BASE engine.
Imagine with a 2.7 TT eco-boost... and maybe even use 93 OCt fuel...
And the reasons I have these dates recorded... both of those days the "traffic" was light enough that I can drive... since pretty much every work day it's stop and go traffic... which gives me from 17.5 to 25 MPG (yes it's that wide a margin).
In my opinion, depending on what he wants to tow, I would open my options up to a later model with a 2.7.
To trade vehicles just for better fuel mileage while towing is one of the worst financial decisions one can make!!! The cost differential of the new vehicle vs the cost of the fuel for the old vehicle will likely NEVER be made up. Remember, you will still have to put fuel in the new rig! And you can buy a LOT of fuel for the cost of the new truck.
Now if you just want a new truck, that is a different story.
Caution when using the lie o meter for fuel economy. I see the lie o meter more as a tool to help you improve driving habits for better mpg. Really need to calculate several full tanks worth of gas to accurately determine actual mpg. There are several variables...fuel quality, driving route, and don't forget how your truck is leaning when you fill up. High 20's for mpg on a full size 4wd is better than excellent. Add a 24' trailer and it's incredible.
My trucks meter usually comes out extremely close to hand calculated mileage. My truck is programmed for 34.1" factory tires, but I'm running 37's. My speedo is 5% slow vs gps. So I figure my meter probably averaged @5% to much before hand. I never did the math before, but it was always a little high. When I hand calculate now, I add in 5% more miles.
January 2016,, from SE South Carolina to NE North Carolina... mostly back roads and 50-55 mph... 2 people and truck empty. and NO towing...
up I got 23 mpg and down I got 21... 87 Gas... but my truck is broken-in... 140,000 miles at that time.
Hand calculated,, not bad for a 6,600 pound truck and a Nose of a sheet of plywood.
I tow and DD this. It is a 7.3 IDI. Even with a c6 I get 18 to 20 mpg on the hwy. about 16 mpg around town. Towing it will usually stay in the 14-16 mpg range. Even with a worn out IP and Injectors I never see below 15mpg with mostly city and 75+mph cruising on the hwy. I know my idea of a good tow rig is different then a lot of people's though. Instead of spending $$ on a newer vehicle, I spent $3000 on an old diesel that I could wrench on and that would run for 500K miles. I can buy a whole lot of fuel for the difference in price between my van and a newer/fancier tow rig. Just a different perspective.
Looking for truck with best gas mileage while towing 1 car trailer. Looking to stick with the 1500 Size. I currently have a 2005 ford f150 5.4l and get around 10mpg highway driving between 55-65 light footed. Pretty bad gas mileage since my brothers 2014 Ram 1500 gets 18mpg towing 1 car trailer.
2nd: no one here believes that Dodge gets 18mpg towing (unless maybe it's a diesel, but even then..)
so let's be realistic, the Dodge is probably 14mpg at best, and your truck 10mpg. Assuming they each pull the same load along the same route. Proper tire pressures, vehicles maintnenace up to date, no CEL, etc etc.
14mpg along a 112 mile trip will burn 8gallons. Even during Hurricane Irma the Florida gas prices are hovering about $2.69/gallon. That means the tow cost you $21.52.
10mpg on the same trip will burn 11.2gallons, which is $30.13.
So for $9 per trip, you can avoid buying a different truck.
****Sometimes people just just get caught up in the wrong numbers- I have a guy that works for me at $19/hr and he produces a large amount of honest, quality work. I have another guy making $22/hr and he does average work.
The $19 guy is all mad about the $22 guy.
But the $19 guy gets a partial commission on his work, AND lots of overtime. He averages $1200/week.
The $22 guy gets 40hrs except very rare cases of overtime. The $22 guy makes under $900/week.
focus on the right things.
