hypertech still the only choice?
Old Sep 6, 2017 | 04:17 AM
2017F250KR's Avatar
2017F250KR
Lightbulb hypertech still the only choice?
I want to run 37's but I would like for all my speedo calibrations to be accurate. I've read were forscan can modify it somewhat but not up to a 37. Has any other manufacturer come out with a different option besides pulling the dash apart to install the hypertech. Also anyone have any experience with the hypertech and if so could you share your results. Thanks
Old Sep 6, 2017 | 05:28 AM
Poncho450's Avatar
Poncho450
I used an SCT X4 device from 5 Star Tuning that would adjust the tire revs per mile to a certain extent to make the speedo more accurate on 2014 and 2016 F250 gassers that I owned.
Other than that I didn't see a whole lot of improvement with the particular tunes I used. But that's another thread and another argument for some guys.
Old Sep 6, 2017 | 06:22 AM
RugbyRef's Avatar
RugbyRef
As of last Friday, I don't think so. I have the Hypertech installed on my truck and it works like a champ! I, too, have 37's on my truck and searched relentlessly for something to program the new tire size. The only thing I do not like about the Hypertech is that when I change out my front/rear diff, I will have to reprogram the module from my laptop. Which means...taking the dash apart to get to it (although it was rather simple). I wish there was something out there I could use through the OBDII connection. Unfortunately, FORSCAN won't do it to tires that size.
Tim
Old Sep 6, 2017 | 08:13 PM
2017F250KR's Avatar
2017F250KR
Tim
So what gear ratio do you have originally and what ratio are you planning to go with? Just curious because I currently have 3.55.
Old Sep 6, 2017 | 10:22 PM
2017-350's Avatar
2017-350
EZ Lynk isn't capable of changing the tire size?
Old Sep 6, 2017 | 11:00 PM
CO Wapiti's Avatar
CO Wapiti
I would like to have my speedo corrected as well. I'm a little paranoid about the Hypertech though until there are some more positive reports. About six months ago, someone had it installed and it was causing enough computer havoc that he had to take it to the dealer, eventually having to disconnect the Hypertech unit.
Old Sep 7, 2017 | 06:24 AM
RugbyRef's Avatar
RugbyRef
Not sure yet as to what I will change to. I have the same as you, but I am waiting to pull my 5th-wheel for the first time and will make a decision then. Right now everything appears to be okay with the 37's and the stock diff's. No laboring and shifting is fine.
Tim
Old Sep 7, 2017 | 07:22 AM
CACRanger's Avatar
CACRanger
Tim
This isn't entirely true. I have used FORSCAN to correct my speedometer after installing 37's. BUT, and it's a big but, it has caused a DTC to trigger as the tire size is outside of the manufacturer's specs. Another member, Livnitup is working with FORSCAN to get this corrected, as it is possible on other vehicles. For now, I will just drive with the DTC light, I'd rather have that than the speedo off by ~5-6 mph at highway speeds.
Thanks,
Chris
Old Sep 7, 2017 | 10:40 AM
RugbyRef's Avatar
RugbyRef
Thanks,
Chris
Interesting Chris...I could not get FORSCAN to go any higher than 275's. How did you do that?
Old Sep 7, 2017 | 10:55 AM
C_Smitty's Avatar
C_Smitty
Currently EZ Lynk only goes up to 34.5 inch tall tires. Hopefully in a later firmware update they give us more options to go taller.
Old Sep 7, 2017 | 02:25 PM
CACRanger's Avatar
CACRanger
I used the below spreadsheet to calculate the correct hex value for my tire size.
https://docs.google.com/spreadsheets...EqU/edit#gid=0
Thanks,
Chris
jeffg_208
Nov 9, 2018 08:55 PM
jlmotox
Jul 19, 2014 12:54 AM
jlmotox
Jul 17, 2014 01:29 PM
drj777
1997 - 2003 F150
18
Mar 20, 2007 03:18 PM
rhicks_all_taken
2004 - 2008 F150
Oct 15, 2004 10:48 AM
