Spout wiring
Spout wiring
Where does it go? I'm fairly confident there is a short in the wiring to the spout, and rather than pull my intake again to get to the engine harness I'd rather just run new wires and mount the spout in a more accessible spot
It's a 5.0L out of a 96 explorer swapped into an 03 ranger
Are you sure that engine is originally out of a 1996 Explorer? Per the factory service manual, the ignition coils on the 5.0L are directly triggered by the PCM and there is no SPOUT connector like older units where there was a separate ignition control module. Or is it maybe not a SPOUT connector?
-Rod
-Rod
-Rod
-Rod
i did tryy something new this morning and so far its running better. i dont know what the part is called but its mounted to the coilpack, little black square looking thing with 1 wire going to it, i unplugged it and it seems to be running a whole lot better, so im guessing whatever that thing is might be bad
Pretty sweet looking rig, by the way!
-Rod
hallfleming
08-03-2020 12:57 PM
CTroxtell
11-07-2019 06:39 PM
WillFargo
12-11-2011 09:55 AM
