Sponsored by: Real Truck
Keyless entry code
Old Sep 2, 2017 | 10:03 PM
SnowPlowDriver's Avatar
SnowPlowDriver
Keyless entry code
Here is a tip for anyone purchasing a used superduty with keyless entry. On a 2011 I recently acquired I found the code on a wire loom near the fuse box on passenger side kick panel.It the only loom that has five numbers.
Old Sep 3, 2017 | 04:36 PM
mdayz28's Avatar
mdayz28
I forgot how to do it but if you have your original code you can put in a new code that is easier for you to remember and if for some reason you forget your new code the factory set code will also work !
Old Sep 3, 2017 | 04:40 PM
seville009's Avatar
seville009
explanation here.....
https://www.ford-trucks.com/how-tos/a/ford-f150-f250-how-to-reprogram-door-keypad-code-356127
Old Sep 3, 2017 | 04:42 PM
mdayz28's Avatar
mdayz28
I think if you type in the original code in and then within 3 secons of it type in your new 5 digit code it will then use both codes but if you type in the original code after you set in your new code it will delete your new code you had set and go back to the factory code . Also on the Ford Expeditions the door code is on the air box in that same location you had mentioned by the passenger foot well area !
Old Sep 3, 2017 | 04:44 PM
mdayz28's Avatar
mdayz28
Thanks , I wonder if I remembered it wright ?
Old Sep 3, 2017 | 04:51 PM
mdayz28's Avatar
mdayz28
Good video by the way !!
jnobles06
Aug 25, 2018 04:19 PM
scotterd
Jul 27, 2015 06:43 PM
86paGT
Dec 28, 2008 10:40 AM
Harley320
Jul 12, 2008 12:33 PM
jmccpa
Sep 30, 2006 08:11 PM
