460 running parched
Old Sep 2, 2017 | 02:55 PM
Miguel4532's Avatar
Miguel4532
460 running parched
I am convinced the dentside gods have placed a curse on me. I can't seem to get any fuel out of my fuel tank. I put in a fresh Holley mechanical fuel pump, new AN fuel lines, Brand new fuel tank, and a new fuel sender. Prior to putting in the fuel lines I cranked the hell out of the motor so maybe the fuel pump was workin extra hard. I have no idea what to do now. Anybody got any ideas?
TRUCK INFO:
Ford 460
1974 F-350 SCS
Old Sep 2, 2017 | 07:37 PM
Blue and White's Avatar
Blue and White
A couple of tests might help track down the problem. 1) priming the engine with ~1/2 teaspoon of gas down the carb 2) run from a can. Submerge a length of rubber hose in a gas can and hook the other end to fuel pump inlet. See if she runs that way.
Old Sep 2, 2017 | 07:38 PM
Filthy Beast's Avatar
Filthy Beast
Ideas? Yupp...
Disconnect the fuel feed line at the fuel pump....the one from the tank, and empty it in a clean container. Have a helper put some air in the tank at the filler cap and cover the hole with a rag - not too much air - about 10 psi or less and observe the container.
Got gas?
If yes, reconnect everything and disconnect the fuel line at the carb's input....again putting the hose/line in a clean container. Crank her over and observe the container.
Got gas?
Hook everything back up....peek down the venturi while blipping the throttle. Should see a coupla squirts of fuel shootin down the throat. No? Accelerator pump time....Yes? Make sure you have spark at the plugs.
If no, recheck all the fittings/connections for tightness...you don't want to be sucking air through the lines....if the lines are what diameter - 3/8"? Recheck with air.
Got gas now?
Repeat the above disconnection to the carb........etc.
Old Oct 19, 2017 | 09:11 PM
Miguel4532's Avatar
Miguel4532
Originally Posted by Filthy Beast
Ideas? Yupp...
Got gas?
Got gas?
Got gas now?
Thank You! It turned out some big piece of dirt/grime got stuck in the fuel line when i was putting them in place. Thank You both my stroker is chugging gas and I love it!
F460bigbore
Dec 26, 2018 11:55 AM
Speedymaru
Aug 21, 2016 09:16 PM
6Fastback7
1978 - 1996 Big Bronco
Aug 8, 2013 07:48 AM
keyul
May 23, 2011 08:34 PM
55Bubba
Aug 16, 2004 01:47 PM
