Need Some Help With 4.9 L I6 !!!
Old Sep 8, 2003 | 02:05 PM
grant925's Avatar
grant925
Question Need Some Help With 4.9 L I6 !!!
FIRST THINGS FIRST IM NOT EXACTLY A MECHANIC SO KEEP IT SIMPLE PLEASE
I HAVE SEVERAL QUESTIONS, FIRST WHAT IS THE HP AND TORQUE SPECS FOR A STOCK 4.9 L
I AM SICK OF THE BORING STOCK EXHAUST WHAT WOULD SOUND BEST ON THIS 6 CYLINDER, IVE HEARD FLOWMASTER SOUNDS LIKE A GRAIN TRUCK, AND IVE HEARD GLASSPACKS SOUND LOUSY
GIBSON SIDESWEPT CATBACK EXHAUST SOUNDS PRETTY GOOD BUT I DONT HAVE CATS NEMORE WOULD THAT AFFECT ALOT ON THAT EXHAUST.
WHAT AFTERMARKET PARTS WOULD ADD THE MOST HP, I WAS THINKING HEADERS BUT NOT SURE ANY SUGGESTS WOULD HELP
WOULD 35X12.5 TIRES BE TO BIG FOR A 4.9 L TO PUSH AROUND AND NOT AFFECT MPG TO MUCH (I WAS THINKING I WOULD LOSE ALOT OF POWER)
THANKS
89 F150 XLT LARIAT 4.9L 4 INCH LIFT 33x12.5 BF AT'S LOTS OF EXTRAS
Old Sep 8, 2003 | 02:56 PM
sandrat's Avatar
sandrat
Exhaust: Straight pipes off the manifolds
Aftermarket performance: Not much, other than ignition and a chip (IMHO.) Don't bother with headers. From what I've read, the manifolds you have are basically headers already, so you wouldn't gain much.
I think those tires might be a mite too much, depending on your gears.
Old Sep 8, 2003 | 03:27 PM
offroadford4x4's Avatar
offroadford4x4
EFI 4.9 is around 150HP
Best exhaust is 2inch daul inlet 2 1/2 inch single outlet high flow cat. 2 1/2 inch single inlet with either 2 1/4 or 2 1/2 dual outlet Magnafow muffler with 3inch or bigger tips. Don't waste money for the header, it doesn't fit EFI without modifing and flow is the same. Keep the stock manifolds.
Regear to 4.10's or lower for 35inch tires.
Get a chip (or Power programer if its a 96). K&N FIPK or equivalent( open filter replacing the stock air box). Electric fans for the radiator.
Old Sep 10, 2003 | 07:12 AM
bigmike09's Avatar
bigmike09
stock specs for your truck
145hp
260 torque
This is from ford.Hope this helps
