so, about a month ago i was rear ended. minor fender bender. however truck has been acting up ever since.
i have a 95 f150. 351w 4x4. dual tanks. truck has 85000 miles on it and overall is very good shape. however, all of a sudden (after driving around town during the day fine) i jumped back in to take off and i went to hit the key and i immediately noticed no fuel pump sound. i tried starting anyway and sure enough she wouldn't fire. i tried toggling between tanks and neither tank will prime. however the fuel gauge does go back and fourth for each tank level like normal. there is an audible click when i turn the key to run before ignition but thats all. i have read many many forums and articles on this sight and others and cannot diagnose this situation.
here is what i know and what ive tried so far.
1. checked the fuse, its good
2. i had a brand new relay so i plugged it in, no change (also swapped it with horn just to be sure)
3. checked inertia switch, its in correct position. ( note: i put a test light on it and it is receiving juice out of i believe the green/yellow wire)
4.went back under the hood and checked for corrosion around fuse box.
now here is where it gets really annoying
i unplugged both wiring connections for front and rear to check for corrosion. they still had the factory dielectric grease in em and were super clean. i didn't have a helper so i tried to see if they had power but couldn't do 2 things at once. i plug everything back up, and last minute decide to try one more time and see if i could here the click again when trying to start. and she actually fired right up and idled normal. i let it run for about 5 minutes and then decided to try switching tank, i switch to the front tank and the truck died. i switched back to rear tank and tried to start and it would not.
i know this post is a little long but i wanted to be thorough and hopefully somebody smarter then i am can shed some light before i start taking the tanks down and the pumps out. thank you in advance!
Dark Green/Yellow wire is power TO the inertia switch. The output is Red/Yellow.
A diagram that might help:
You can jumper Pins 2 & 6 on the diagnostic port then turn the key to the Run position to keep the fuel pump relay energized. Use a test lamp to verify power is leaving the inertia switch. Might be worth a shot to trip it then reset.
thanks for the diagram. i have read in a few places about a test port. what do you mean by that and where would that be? thanks
Test Port or Point
A pressure test point with a Schrader fitting is in the engine fuel rail to relieve pressure in the fuel system and to measure the injector supply pressure for service and diagnostic work.
