Sponsored by: Real Truck
Icp and ipr
Old Aug 29, 2017 | 08:36 AM
William Sanders's Avatar
William Sanders
Icp and ipr
My truck was running fine, it's stock as far as I know. Shut it off, it sat and cooled off for a while. When I tried to crank it, it wouldn't start, threw 2 codes. P2285 and p 2623. I unplugged the icp sensoran tried to start, no start. Plugged it back in and it started fine for the rest of the work day ( I work out of it). Drove it the next day without any issues. Today went to start before work and no start with the same 2 codes. What should I check first? I don't have any monitor yet, any help would be very much appreciated! Bought the truck a month ago as a work truck. It has 164000 miles.
Old Aug 29, 2017 | 07:47 PM
redford's Avatar
redford
FTE Leadership Emeritus
Year and engine?
Old Aug 29, 2017 | 08:24 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Profile says '06, codes say 6.0.
ICP sensor connector was dry when you pulled it, not covered in oil? Absent computer diagnostic capability, pull the IPR valve and inspect it and it's wiring. Screen should be intact and not cracked, wire connector should be tight, dry, and not cracked. There's a special socket that makes removal easier:
Amazon Amazon
Screen and seal kit for the IPR valve:
IPR Injection Pressure Regulator Seal Kit 03-07
And the IPR wiring harness if it decides to crumble apart on you:
IPR / VGT Soleniod Pigtail Connector Repair Kit 94-07
Old Aug 29, 2017 | 08:59 PM
redford's Avatar
redford
Amazon Amazon
Sorry. On my phone using the GT app. Can't see signatures or most of the profile.
Old Aug 29, 2017 | 10:34 PM
texastech_diesel
Token Redneck
No worries Stu, figured I'd take a crack at it. I could still be wrong, you know what assuming does to people
jeffl1107!
Oct 13, 2014 07:36 PM
dardick
16
May 16, 2013 08:25 PM
luny1
May 20, 2010 07:30 PM
89BlackBeauty
41
Apr 4, 2009 01:07 PM
dofthew
Apr 22, 2008 09:51 PM
