67 F-100 4x4 restoration
Old 09-05-2017, 07:16 AM
67nukeford's Avatar
67nukeford
67nukeford is offline
Love the cab lift you came up with!
Old 09-05-2017, 11:32 AM
cstoyer's Avatar
cstoyer
cstoyer is offline
Yes, better than the tie down straps to 4 corners of the cab and engine hoist that I did when I took mine off.
cstoyer
Old 09-05-2017, 01:11 PM
Brian1971f100's Avatar
Brian1971f100
Brian1971f100 is offline
Very nifty lift set the MPH. I just might borrow that idea in the future. Keep up the good work
Old 09-05-2017, 02:14 PM
67nukeford's Avatar
67nukeford
cstoyer
Yep, me too, didn't work worth a damn!
Old 09-05-2017, 04:29 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Originally Posted by mrpotatohead
I see that all the typical aftermarket suppliers offer radiator support and cab rubber mounts for 2 wheel driver trucks but I haven't seen any listed for 4 wheel drive trucks. I wonder what the difference is and are all of them different or just the front ones for the radiator support.
Has anyone found a source for them for the 4x4's?
Looks like the PO was doing some clutch dumps. NICE idea on the cab lifting.
As you can see above the 4X4 cab mounts are the same front and back. No 1 is the front and No 2 is the rear. The 4X2 takes the same in the front. But the rears are different. I guess everybody trying to force a 4X4 owner to buying 2 kits for one truck.
Old 09-05-2017, 06:26 PM
mrpotatohead's Avatar
mrpotatohead
mrpotatohead is offline
Thanks Jeff, I'll digest this info after work.
Old 09-05-2017, 11:53 PM
mrpotatohead
Jeff, I can't make heads or tails of this. Can you list the part #'s that I need for this 67 F-100 4x4? I need the upper and lower rubbers for all 3 positions, the bolts, nuts and inner metal sleeves.
Old 09-06-2017, 07:23 AM
67nukeford's Avatar
67nukeford
I had to buy the 2wd set, and have them cut down in the rear. For the life of me, I can't figure out why they don't sell a 4x4 set.
Old 09-06-2017, 12:08 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Cab UPPER....C4TZ8100154D. Replaced C4TZ8100154C. All four.
Cab LOWER...C4TZ8100155D. Replaced C4TZ8100155C. All four.
Cab rear upper retainers....C6TZ8100163B.
Cab front upper retainers...C4TZ8100163A.
Cab lower retainers....C4TZ8100157B. All four.
Rad support UPPER...D3TZ1000396C.
Rad support LOWER...C5TZ8100155A.
Old 09-06-2017, 02:01 PM
67nukeford's Avatar
67nukeford
Good luck finding those retainers, I looked high and low for those damn things! Ending up with Dennis Carpenters 2wd set.
Old 09-06-2017, 02:08 PM
mrpotatohead
A lot of the problem for me is the terminology:
There are upper and lower rubber mounts, inner steel sleeves, washers, nuts and bolts. What's a retainer?
Old 09-06-2017, 02:10 PM
mrpotatohead
So then is it just the rear ones that are different on the 4x4's?
  #28
Old 09-07-2017, 07:59 AM
67nukeford's Avatar
67nukeford
Yep. All four mounts are the same on the 4x4's. I tried to get Dennis Carpenter to send me two sets of just the 2wd fronts, but they wouldn't, for whatever reason. So, I had our machine shop here at work cut the rear set down to match.
  #29
Old 09-07-2017, 09:02 AM
mrpotatohead
Nuke, when you say all 4 are the same, are you talking about the cab mounts or the radiator support mounts also?
  #30
Old 09-07-2017, 09:20 AM
67nukeford's Avatar
67nukeford
Cab mounts. The front mounts are the same on both 2wd and 4x4. The rear mounts on the 2wd are thicker than the 4x4 mounts.
Quick Reply: 67 F-100 4x4 restoration
