I see that all the typical aftermarket suppliers offer radiator support and cab rubber mounts for 2 wheel driver trucks but I haven't seen any listed for 4 wheel drive trucks. I wonder what the difference is and are all of them different or just the front ones for the radiator support.
Has anyone found a source for them for the 4x4's?
Looks like the PO was doing some clutch dumps. NICE idea on the cab lifting.
As you can see above the 4X4 cab mounts are the same front and back. No 1 is the front and No 2 is the rear. The 4X2 takes the same in the front. But the rears are different. I guess everybody trying to force a 4X4 owner to buying 2 kits for one truck.
Jeff, I can't make heads or tails of this. Can you list the part #'s that I need for this 67 F-100 4x4? I need the upper and lower rubbers for all 3 positions, the bolts, nuts and inner metal sleeves.
Cab UPPER....C4TZ8100154D. Replaced C4TZ8100154C. All four.
Cab LOWER...C4TZ8100155D. Replaced C4TZ8100155C. All four.
Cab rear upper retainers....C6TZ8100163B.
Cab front upper retainers...C4TZ8100163A.
Cab lower retainers....C4TZ8100157B. All four.
Rad support UPPER...D3TZ1000396C.
Rad support LOWER...C5TZ8100155A.
Good luck finding those retainers, I looked high and low for those damn things! Ending up with Dennis Carpenters 2wd set.
A lot of the problem for me is the terminology:
There are upper and lower rubber mounts, inner steel sleeves, washers, nuts and bolts. What's a retainer?
Yep. All four mounts are the same on the 4x4's. I tried to get Dennis Carpenter to send me two sets of just the 2wd fronts, but they wouldn't, for whatever reason. So, I had our machine shop here at work cut the rear set down to match.
