Finally was able to find all the upper and lower cab mount rubber bushings from different sources. Paid too much but I just wasn't happy with the hard as hell Prothane ones. I found the lower retainers ( washer and sleeve assemblies really) but they are 20.00 each and I need 4! So far I haven't been able to find the upper retainers yet: Rear-C6TZ-8100163-B. Front-C4TZ-8100163-A but I'm still looking.
I tried to get Dennis Carpenter to send me two sets of the front mount pads/ washers/ and retainers. They are the same as the rear on the 4x4. But, they wouldn't (and for some stupid reason, won't create this set for he 4x4's), so, I had our machine shop here at work turn down the pads, and cut the retainers to match the front.
Been a little lazy on updating progress so here's the latest. Waiting on my new dash pad to be delivered; should be today, then the interior is done with the exception of the rubber/vinyl flooring. That stuff doesn't want to lay down until warmer weather.
