Intake manifold V10 Excursion
Old Aug 25, 2017 | 04:22 PM
sandersnc's Avatar
sandersnc
4wd High
What are signs the intake manifold may be cracked? 2001 V10 Excursion
Thanks in advance
Old Aug 25, 2017 | 04:48 PM
R&T Babich's Avatar
R&T Babich
Haven't heard of any intake manifold cracking issues for the 6.8L.
You might have a leaking gasket.
Are you working on a vacuum or coolant issue?
For a vacuum issue the PCV hose is probably the first place to check.
Old Aug 25, 2017 | 05:36 PM
rock2610d's Avatar
rock2610d
A cracked intake would sucks in air that is not metered so computer will be confused and motor will not run right. Expecially at high vacuum/idle.
For example if you pull a vacuum hose off a good running motor while running it will stumble and idle poorly.
That's the sign of a cracked intake.
Old Aug 25, 2017 | 07:48 PM
sandersnc's Avatar
sandersnc
4wd High
I have a coolant issue. White smoke from the tailpipe. Level changes very little.
Old Aug 26, 2017 | 01:05 AM
Sam I Am's Avatar
Sam I Am
More likely a failed head gasket or intake gasket.
eyewall
Mar 24, 2016 08:06 AM
peteruss
1997 - 2003 F150
Aug 8, 2013 06:18 AM
jerrycarl
May 20, 2003 02:21 PM
woodworks66
Apr 19, 2002 09:50 PM
