5.4 E350 Extended Van
The 5.4 has a lot more giddy-up go than my old 5.0 had, but: I think I may have to put it on a 12 step program for its drinking problem!!! Even if I drive like a little old granny, the mileage is still brutal.
Is this normal for this particular beast or is there an easy cure for this?
I'm getting about 10 m.p.g.
Do you know if the 100,000 mile tune-up and maintanence was done? If not:
1) New wires (Motocraft) and plugs (Motocraft or Autolite double plats)
2) new O2 sensors ( the 2 closest to the engine)
3) New coil packs. Replace ALL 8. Expensive but, hey, 125,000 miles THEY ARE TIRED.
4) New air filter, PCV and check EGR system for carbon build-up.
5) Clean the MAF sensor.
If you read gkbid's post "sounds like a diesel @ start-up" you will see his 5.4 Expy with over 100K miles went from 10.5 to 15.4 MPG after changing plugs, wires. coil packs and EGR. Let us know your results.
Good Luck,
Bill
I assume your truck is running normally and you have no "CEL" since you did not mention it. Since you only have 75K miles on it I'd say the same advice applies but in this order:
1)Clean the MAFs. Replace PCV, air filter and remove and inspect EGR for carbon build-up on the valve and the tube. Reset the PCM and drive normally for a tankful or two. Check your MPG.
2) If not happy, replace plugs and wires.
3) Still not happy replace O2 sensors.
4) Replace coils
Again, Good Luck,
Bill
1) Any opinions on using methanol gas?
2) Is there a website for servicing and engine parts layout?
At 12K your plugs should be good. Did you check that ALL the plugs were replaced? I've heard that some techs who have trouble with a tough plug or two may leave the old one(s)in the engine. Were the wires changed?
Did you.....Clean the MAFs. Replace PCV, air filter and remove and inspect EGR for carbon build-up on the valve and the tube. Reset the PCM and drive normally for a tankful or two. Check your MPG?
Did you.....replace O2 sensors?
Did you.... Replace coils?
Methanol?. Now your really opening a can of worms. I'm not an expert but I will state a fact and let you draw your own conclusions. Methanol has less energy per unit volume (call it ounces, gallons or ml or litres) than gasoline.
I don't know a website with engine layout etc. Go to e-bay. It has Ford CD's for sale.
I installed a K&N air filter last week, seems to have helped (maybe wishful thinking) but haven't refilled tank yet to check mileage.
What are MAF's? and the PCM?
I'm technically challenged and also drive a GMC truck on the week-ends; so please keep it simple and detailed.
Thanks,
Fred
My bad on the methanol/ethanol thing. The one carbon Methanol will melt your engine if you use it for fuel. I wrote "methanol" but was thinking "ethanol". Ethanol blended fuels have less energy per gallon than straight gasoline. No two ways about it. It may burn cleaner but you have to burn more of it per mile. So what's the point? For example : it burns 8% "cleaner" but you get 10% less MPG. Seems to me your making 2% MORE POLLUTION and paying through the nose for the privledge!
The MAF is the (M)*** (A)ir (F)low (s)ensor, It must be kept clean to properly meter the air entering your engine. The PCM or (P)ower(T)rain (C)ontrol (M)odule uses this info and that from other sensors to control air fuel ratio, spark timing etc.
Suffice it to say, if you MAFs is dirty your engine will run "lean" (too much air, not enough fuel". This is not good for your engine or your wallet!
