Turbo barking. No power
Hi, I just put a new turbo in my truck, and all new intercooler piping. The turbo barks when letting off the throttle. No matter speed or amount of throttle. Has no power compared to what it used to, and there is a weird hissing noise on the front left of the motor. Can't find any leaks from intake, intercooler, up-pipe, down pipes. My wrench light is also on. Don't know what to do
Silly question but did you replace the turbo with a similar vgt type?
If not, you'll get those hiccups without a pressure release valve built in.
You might check to ensure the oil driven "solenoid " that open and closes those vanes is working properly.
Get some gauges on truck as recommended above to help steer you the right direction.
DIRTYSTEVEN
30
01-31-2008 11:28 PM
