52 steering colum
Old Aug 17, 2017 | 01:32 AM
lbrauer's Avatar
lbrauer
52 steering colum
My sons 52 F1 Steering colum needs to be redone but I don't have any idea where to look for the parts. It looks like he needs quite of parts to keep the orignal in truck. Looking in the book and looking at the steering colum after taking it apart he needs # 3520 spring, 3518 Sleeve, 3517 bearing, 3738 felt seal and many other parts for the steering box.
Any help in locating these parts or a new old one would be apprecated,
Larry Brauer
Old Aug 17, 2017 | 02:09 AM
BlueOvalRage's Avatar
BlueOvalRage
The pieces that you're looking for are easily available from a number of suppliers. Mid-Fifty is a good source.
Here's your 3518 sleeve:
1948-73 Ford F-100 Steering Column Top Bearing Retainer Sleeve - B1AZ-3518-A
The 3517 bearing:
1948-56 Ford F-100 Steering Column Top Or Upper Centering Bearing - 21A-3517
3520 spring:
1948-60 Ford F-100 Steering Column Inner Worm Shaft Upper Bearing Spring - 8M-3520
and 3738 felt seal:
1948-60 Ford F-100 Felt Dust Seal - 3738
They'll have just about anything else you might need to rebuild the steering gear and column as well. Just plug the 4 digit base part numbers such as you posted earlier into their search bar and you'll find them.
Old Aug 17, 2017 | 08:45 PM
lbrauer's Avatar
lbrauer
Thanks so much for the great information it is greaatly appreciated
Old Aug 22, 2017 | 10:58 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1948/52 F1/F2 & 1953/56 F100/250:
1) B1AZ-3518-A .. Steering Column Upper Bearing Nylon Sleeve - .98" O.D. x .75" I.D. (1949/52 F1/F6 & 1953/56 F100/600 & 1957/73 F100/250).
1) 8M-3520 .. Steering Column Upper Bearing Spring.
1) B-3552 .. Upper Steering Shaft & Worm Bearing Cup.
1) 8A-3553 .. Lower Steering Shaft & Worm Bearing Cup.
2) 68-3571-A .. Upper & Lower Steering Shaft & Worm Bearings.
2) 78-3576-A .. Sector Shaft Bushing (1948/52 F1/F2/F3 only).
1) 7RC-3581 .. Sector Shaft Cover Gasket.
1) C3AZ-3591-A .. Sector Shaft Seal (1948/52 F1/F2/F3 only).
The 3738 steering shaft felt seal is not used on 1948/52, only used on 1953/56 F100/250.
All the above parts are available NOS .. The nylon sleeve is also available from Ford.
Mikes67F250
Feb 3, 2015 06:36 AM
avf100
Jun 29, 2014 08:10 PM
cordele79
Jan 22, 2013 03:11 PM
66 4x4
Oct 17, 2012 03:24 PM
ericeugunep
Sep 27, 2008 05:59 AM
