2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Power Steering Pump Replacement Question
Old Aug 16, 2017 | 09:57 PM
thefordfanatic's Avatar
thefordfanatic
Has anyone replaced the power steering pump? If so, do you have any pointers on removal? I searched high and low for a write up, but have come up short. I'm mainly stuck on removing the fan shroud and the harness that goes over the top of the top part of the fan shroud. Any help would be appreciated.
Old Aug 18, 2017 | 12:33 PM
D-Rock's Avatar
D-Rock
It sounds like you may be trying to do this from up top - this job is best done from underneath. The fan shroud folds up in half (like a clamshell) from underneath. This gets you accessibility to the fluid line fittings and the mounting bolts. It's not a difficult job, but is messy and requires a measured level of patience. Good luck.
Old Aug 22, 2017 | 12:13 AM
thefordfanatic
Thanks D-Rock! That's good advice. I appreciate it.
ojai150
2004 - 2008 F150
Jul 25, 2017 08:45 AM
Aminator
Sep 4, 2012 02:29 PM
rpenterics
2004 - 2008 F150
Jul 5, 2011 11:30 AM
f15097
1997 - 2003 F150
Sep 25, 2010 03:09 PM
mongo75
Dec 31, 2009 08:18 PM
