It's not a perfect picture but it's the best I've got at the moment because our internet is down and I'm having to do everything via my cell. I hope it helps. I wish I had before pictures. These LEDs are much brighter. I don't think I'd leave the blue filters out unless I had colored bulbs. Mine were cloudy too but they were too old to polish without damaging. The only thing is the variable adjustment for the brightness is kind of all or nothing because of the way LED bulbs work. I can live with that.
Thanks. I think I'm going to get the white bulbs on amazon and leave the blue filter.. so same concept as factory just brighter. I'll post up my afters when I get them to compare with my incandescent bulbs. Any idea on how much of a job it is to get to the gear selector and heater control bulbs?
Heater control you might be able to reach up from behind with no AC? I've never tried, but you can for sure get at it with the dash bezel off, especially with no radio.
Uh, I've actually never seen how the one in the column goes in! Probably can't be too difficult... I've ever had only an E250 with that setup, and I never got it running.
Have you tested voltage output to the gauge lighting circuit aft of the rheostat dimmer?
Never pulled a steering wheel. Easy to do with hand tools? I've been wanting to get one of those wooden styled ford wheels like in lmc or something similar.
Just one nut which is easy to take off - assuming you have the horn-pad off...
You might be able to get the wheel off by pounding with your hands, but a steering wheel puller will make it easy.
You probably can rent/borrow one from the McParts store, but you can also buy one there for cheap.
I bought one when I needed it years ago, and have used it other times since, most recently on my Dent, which had its wheel on crooked... Very nice tool to have when the need for it rolls around!
The wheel is held on by a nut which is threaded onto a shaft with splines. Take the nut off, then try to get penetrant like PB Blaster into the splines. Now this is the counter-intuitive part - TIGHTEN the nut hard, hopefully pushing the wheel a tad further into the splines, then remove the nut again. This helps break the hold of the splines on the wheel and if you get lucky, will help the penetrant get just a bit further in the splines. A puller is best. If none available, you can try to get the wheel loose by hitting the back of the wheel arms with a rubber mallet while pulling on the opposite side of the rim - but note that you are whacking and pulling on 40 year old plastic and you can damage the wheel like this. Also - if you do that, thread the nut a couple of tuns back onto the shaft before starting to whack - sometimes the wheel comes off all at once in a hurry and I guarantee getting hit in the face with one hurts. Trust me on this.
Good idea on the tighten the nut a bit more to help break it loose, you just DO NOT want to strip that shaft for sure.
I can say that buying a tool that pulls harmonic balancers, steering wheels, pulleys, and gears for 15 to 20 bucks is a better way to ensure you do not break you steering wheel or your face.
Good info and tips for the steering wheel. Don't know how soon I'll get to it but I'll definitely use the tips.
My lights came in today however after spending all day with a shovel in my hand digging 4' holes in my yard.. I decided to jump into the pool and head inside for dinner and bed. Hopefully tomorrow some time I'll change them out!
Ok, finally had time to mess around with the led dash lights I got from amazon. Changed them out and everything went well. The dimmer also still works with these lights. I read some reviews that people said their dimmers didn't work.
Before. The picture actually make the old lights looks brighter than they actually were. Even in pitch black they were very hard to see.
That looks great.
Whether LED's dim or not depends on the bulb (and probably the dimmer as well) working together. Many LED's simply do not work with a rheostat, so those that post that theirs don't dim are usually correct and telling the truth in their case.
Great that yours do dim though. Score!
