160/0 injectors vs 160/30 for daily driver
#31
on
It doesn't seem a lot of "new" tuning stuff is coming out for our 7.3L lately. I missed the big development stages (maybe that's a good thing- window'd blocks )
Maybe some better tunes will be coming out from everyone? Renewed interest in 7.3 tunes (and turbos!) could be good for our dinosaurs
#33
I would personally run 80% nozzles. 160's seem like a waist of money to me but if your not looking for power then 160-80% would be what I would choose. Now I have 238-80% and have had loads 19-20k behind my truck making everything in the 31k zone in the pnw pulling 7-8% grades at 55-60mph. I have gear head tunes and couldn't be happier with them. It's really all in the tuning on how your truck performs if everything is healthy. I went with the largest injector Gearhead recommended without live tuning, (80% just because there cleaner than 100's) so I would rather have a much larger injector turned down to make what a 160 would make power wise for towing and grow into the injectors down the road with supporting mods. My brother has 238-80's in his OBS with the stock charger and it does fine (2yrs now). His hi tune makes less HP than my low tune. Just something to chew on I don't like spending 2k just to be disappointed that I didn't go bigger when I could do what I did and have them turned down to what the 160's would doing maxed out.
#34
Built trans
Complete fuel system
Studs, valve springs, and pushrods (these might be optional from what I've read but I'm not sure)
Turbo
HPOP (depending on health of mine)
#35
This makes hybrids sound very appealing. I knew they could be detuned, but I didn't know how much. Those towing numbers are extremely impressive, another reason that hybrids sound great. I think I'd be happy with around 400hp/800tq to the wheels. I know that 160/80 would hit those numbers, but it'd probably be on the wide open tune which I'd prefer to not drive around in constantly. Hybrids would hit those numbers with no issue. I'm just not sure if I'm up for all of the supporting mods down the road. Correct me if I'm wrong, but does this list of supporting mods sound about right?
Built trans
Turbo
Built trans
Turbo
#36
Any injector can be de-tuned! If you can make 'em idle, you can tune them to make 100 rwhp! The only trade off is idle quality and street manners. The bigger the nozzle, the more precise the tuning needs to be. Bigger nozzles will also lead to more smoke on initial pedal tip in, before the turbo has a chance to spool. That being said, 80% nozzles are no big deal for the competent tuners to make them behave like stock nozzles.
#37
I was not looking to make big power. I wanted better power and maybe a little extra oomph to get on the freeway. I also didn't want to add too much extra as I have PMRs. For me 160/80 was right up my alley: more fuel capacity, bigger nozzles, uses less oil, lower EGTs, everyone seems to be able to program them no problem, and I'll have my stock turbo for quite awhile longer. I also have a smog every 2 years so want to stay on the mild side to make it easy to keep the truck's stock manners.
#38
I was not looking to make big power. I wanted better power and maybe a little extra oomph to get on the freeway. I also didn't want to add too much extra as I have PMRs. For me 160/80 was right up my alley: more fuel capacity, bigger nozzles, uses less oil, everyone seems to be able to program them no problem, and I'll have my stock turbo for quite awhile longer. I also have a smog every 2 years so want to stay on the mild side to make it easy to keep the truck's stock manners.
#39
I have forged rods (one good thing about an early 99). I got my transmission beefed up pretty good by a local builder, but I need to check with my builder as to just how much power it can hold lol. A stock turbo would live longer and better with some 160/80s, and I'm fairly certain I'd be fine with the power the 160/80s put out. They've gotta be better than the stock 130cc injectors lol. I think for my budget, 160/80s are the way to go...but hybrids sound like a lot of fun!
#42
#44
Just some advice from someone you don't know, but either stick with 160/0 or 160/80. The 160/30 option adds nothing to the ability of the injector, it only adds to the cost.
