I gambled and maybe I
Old 12-30-2018, 09:38 AM
baddad457's Avatar
baddad457
baddad457 is offline
Originally Posted by schoo
Some body on here said I will need a different distributor drive gear if I change cams(comp cam#35-512-8)is this true and if so have you got a part#
Only if you go from a flat tappet to a roller cam (or vice-versa) The cam's materials are different (steel for the roller, cast iron for flat tappet)
  #122
Old 12-30-2018, 11:56 AM
schoo's Avatar
schoo
schoo is offline
ok I’m going to roller cam. so steel are they all the same I believe I also will change the firing order
  #123
Old 12-30-2018, 12:43 PM
baddad457's Avatar
baddad457
As far as I know all roller cams are steel.
  #124
Old 12-30-2018, 06:19 PM
Scndsin's Avatar
Scndsin
Scndsin is online now
Itz been a while so I think this was covered, but your 89 block is "roller capable", it will need a "spider" & "dog bones" to go with a roller cam.
Most all hi-perf small block Ford cams usually have the notation in their specs "must use 351 firing order".
You will need a steel distributor gear. I'd also suggest you take the time to replace the PIP sensor in the distributor since you have to press off the gear.
Use a Motorcraft part.
  #125
Old 12-31-2018, 10:54 AM
Last chance 53's Avatar
Last chance 53
Last chance 53 is offline
I am running a comp cam in my 331 and was told by comp that all the cam part numbers that end in -8 are iron based and a steel gear was not needed. Maybe want to double check before you change to steel
  #126
Old 12-31-2018, 01:25 PM
schoo's Avatar
schoo
schoo is offline
thanks guys info keeps me hopping summits got a steel one for $29.99 and also sell comps plastic one for $💯 so I have a good range to choose
  #127
Old 01-01-2019, 01:01 PM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is offline
The -8 are rollers, so are they steel?
  #128
Old 01-01-2019, 02:17 PM
Last chance 53
The comp cams are a ductile lron core, not billet steel. They use a heat treatment on the lobes to control wear on them.
  #129
Old 01-01-2019, 04:07 PM
schoo's Avatar
schoo
schoo is offline
ok what drive gear am I going to use? I sent an email to comp asking yesterday so don’t expect to here from them soon
  #130
Old 01-01-2019, 05:17 PM
Last chance 53
The tech dept. at comp cams told me I could use the stock iron gear.
  #131
Old 01-01-2019, 05:42 PM
Scndsin's Avatar
Scndsin
Use a steel gear.
This would be fine for your application if you can't a Motorcraft part.
https://www.summitracing.com/parts/sum-850460/overview/make/ford
https://www.summitracing.com/parts/sum-850461/overview/make/ford
Measure the shaft.
(Edit) larger shaft probably for 351/5.8, my bad.
  #132
Old 01-01-2019, 05:45 PM
schoo's Avatar
schoo
schoo is offline
I just found a video by comp cams on summit tech support (I’m old so can’t link it)but it gives a chart and a video shows how to see the difference in cam material and a chart shows drive gear chooses I’m going to use steel
  #133
Old 01-01-2019, 10:15 PM
schoo's Avatar
schoo
schoo is offline
Originally Posted by Scndsin
Use a steel gear.
Measure the shaft.
yes I checked it I have the small shaft
Calling ford tomorrow
  #134
Old 01-02-2019, 11:27 AM
schoo's Avatar
schoo
schoo is offline
Mission creep
Hope this isn’t a bad sign the drive gear for the distributor that I have looks to be a steel/plastic stock drive gear I need to change out I don’t want to change the hole distributor just the gear it has a roll pin and I believe it’s a press on gear. The machine shop I use doesn’t do this so looking around. The ford dealer says it an obsolete part and can’t even get me a part number. A new year project road block?
  #135
Old 01-02-2019, 01:04 PM
Scndsin's Avatar
Scndsin
Wow. That's pretty lame. It's not hard to drive out the roll pin. The physical effort to press off the gear is minimal.
This is the first hit I got on Google. I'm sure there's more:
Quick Reply: I gambled and maybe I
