I gambled and maybe I
Old 12-07-2018, 09:05 AM
fordman75's Avatar
fordman75
fordman75 is offline
If you want a smoother idle, look for a cam with a wider LSA. I believe something in the 112-114 range would work for you.
  #92
Old 12-07-2018, 11:58 AM
Scndsin's Avatar
Scndsin
Scndsin is online now
It's not bad. Gives up a bit over stock from off idle to 1500 which is where it's advertised to come on.
It rumbles around my small town with ease & rarely sees 2k till I hit the highway
It idles before & after mass-air conversion at 750 & has a noticeable 3 second lope. You can literally count it off, but you have to pay attention to really notice.
It runs very hard up till fuel & tune cuts off before what I've learned here is about 5200 though I've never let it run long enough to get there.
It pegs the speedometer easily & WOT on ramps & passing are a blast.
I would suspect with your lighter truck & less hp eating transmission you might could do with more. Or less, but I don't know.
Conaski says my 512 is only slightly more aggressive than my stock 5.8 cam. (which I could give you maybe. New set of lifters & you'd be golden)
But in my warped filing system, I can't locate the actual numbers right now.
  #93
Old 12-07-2018, 02:50 PM
schoo's Avatar
schoo
schoo is offline
Dave I thank very much hoping for other in put guys
  #94
Old 12-12-2018, 05:26 PM
schoo's Avatar
schoo
schoo is offline
Main bearing
Was this caused by the TC
this end looks front
  #95
Old 12-12-2018, 05:28 PM
schoo's Avatar
schoo
schoo is offline
tranny side
  #96
Old 12-12-2018, 05:54 PM
Scndsin's Avatar
Scndsin
First pic crank snout side & second trans side or vice/versa?
Hard to say either way. Doesn't look too excessive.
I'd ask your machine shop & maybe see if a trans shop would look at the torque converter for swelling/distortion.
  #97
Old 12-12-2018, 07:04 PM
schoo's Avatar
schoo
schoo is offline
Yes going to see the transmission builder. That’s 200k on it always hauling a E250 with construction tools so been used
  #98
Old 12-12-2018, 07:44 PM
baddad457's Avatar
baddad457
baddad457 is offline
Probably normal for 200K, compare the wear to the other mains. If they're not in the copper, then you've got excess pressure in the converter. I went through one roller 5.0 that ate all the way through the thrust and had started rubbing the saddles with the counterweights.
  #99
Old 12-13-2018, 01:00 AM
Scndsin's Avatar
Scndsin
OK I didn't see the notations. Looks like the chamfer on the trans side has some excessive thrust wear, but not totally eaten up.
200k seems good.
  #100
Old 12-15-2018, 10:27 AM
schoo's Avatar
schoo
schoo is offline
200k seems good.
I edited that post Dave.
I’m thinking that same cam you used also why the 1.7 rocker versus 1.6?
  #101
Old 12-15-2018, 11:20 AM
schoo's Avatar
schoo
schoo is offline
Got a hole in block don’t know what it’s for so didn’t paint it? It’s on the left side out side the oil pan
  #102
Old 12-15-2018, 12:07 PM
Scndsin's Avatar
Scndsin
I think it's a dowel hole for when the block was machined at the factory.
  #103
Old 12-15-2018, 12:44 PM
schoo's Avatar
schoo
schoo is offline
Ok thanks on the hole info. so rockers 1.7 versus 1.6 what’s the difference
  #104
Old 12-15-2018, 02:29 PM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is offline
The 1.7:1 rocker ratio gives you about 6% more valve lift across the full range of valve lift. Depending on the rest of the intake, it can net some small power gains.
  #105
Old 12-15-2018, 02:34 PM
schoo's Avatar
schoo
schoo is offline
does the pcm/efi like them
Quick Reply: I gambled and maybe I
