Exhaust leak
Old Aug 16, 2017 | 10:32 AM
lincolnshibuya's Avatar
lincolnshibuya
Exhaust leak
I'm suspecting a small leak on my 03 Navigator that seals quickly in a minute after starting. How easy or bad it is to replace the exhaust manifold on an Intech 32v V8 (not a Triton) ?
https://www.facebook.com/diyLincolnNavigator/
Old Aug 17, 2017 | 05:38 PM
alloro's Avatar
alloro
Which side?
Old Aug 17, 2017 | 09:28 PM
lincolnshibuya
Originally Posted by alloro
Which side?
both, I'm thinking that engine needs to be pulled up because of the shock tower.
Old Aug 18, 2017 | 02:37 PM
alloro's Avatar
alloro
The passenger side is the easier of the two. Remove the wheel and wheel well liner for easier access to the manifold. Once the manifold is out inspect the tranny dipstick tube for signs of perforation.
For the drivers side, again remove the wheel and wheel well liner for easier access to the manifold. This side is harder because the oil dipstick tube, the steering shaft, and the EGR tube are in your way.
Old Aug 19, 2017 | 10:22 AM
RealtorTim's Avatar
RealtorTim
I thought I had that issue on my 03. When I crawled under it i notice one of the bolts where the 2 meet before the muffler had some out and was sounding a lot like the manifold. put a new bolt in and solved it. Maybe worth checking that first.
Old Aug 20, 2017 | 02:10 PM
lincolnshibuya
I did check those already and even replaced the gasket prior to the muffler. I tried smoke test to check the leak but it doesn't work, can't find any that I know of. I suspect that it maybe because of the aftermarket muffler but I kind of suspecting an exhaust leak on the manifold because it ticks like for 10 secs on startup and goes away, step on the throttle and exhaust is loud.
Doc
1997 - 2003 F150
19
Sep 22, 2016 10:14 AM
ebraunusa
Jan 13, 2010 10:18 PM
dsheleg
Jul 14, 2007 04:42 PM
jlouki01
Sep 12, 2006 09:25 AM
JLD
May 24, 2004 11:23 PM
