Sponsored by: Auxito
Help decoding codes in door jam
Old Sep 7, 2003 | 07:29 PM
ScofieldNkjv's Avatar
ScofieldNkjv
I have a 1999 E-150 and I have the codes (Heading / Code) R / K, Axle / 19, TR / U. In searching it appears the 19 stands for 3.55 gears(?). Any help would be appreciated. Is there a code for limited-slip?
Old Sep 7, 2003 | 08:17 PM
kspilkinton's Avatar
kspilkinton
H9 is the code for a 3.55 Limited Slip rear. The 19 does mean a 3.55 open in your case. U under trans is the 4R70W, R is the radio code or "what did the van come from the factory with?" My truck is a "5" for single indash CD player with radio and regular speakers.
If you check the tech articles section we list most of the codes in a door jamb sticker decoder. While it lists trucks, the vans follow most codes, we don't list the radio codes though. The radio may be different from a truck, anyhow, depending on speaker configuration (more room, more speakers).
-Kerry
Old Sep 8, 2003 | 06:45 AM
ScofieldNkjv
Kerry, thank you for the reply, you have been most helpful! This is my first time to this site so thanks for the tip on Tech Articles. The radio in my van is a CD/Tape/AM-FM; there was also a code of HC with a heading of SPR (or SKR), I assume that is speakers, I will check Tech Articles.
I figured it was an open rear-end, I don't suspect to many vans are ordered with limited slip.
Thanks again for the help.
Old Sep 8, 2003 | 06:49 AM
ScofieldNkjv
...just a followup, I did find the decoder, thanks. I now see SPR is Springs not Speakers.
Old Sep 9, 2003 | 07:11 PM
kspilkinton
Glad we could help... that's one of the main reasons we're here...
-Kerry
xrsfsho
Mar 26, 2015 09:44 AM
cboland
1983 - 2012 Ranger & B-Series
Nov 19, 2013 06:16 AM
ManfredVonRichtofen
1978 - 1996 Big Bronco
Sep 11, 2012 12:16 PM
BLAVET4X4
2004 - 2008 F150
Aug 13, 2011 11:40 PM
Shane
Mar 8, 2000 09:11 PM
