OPEN or LS ?
Old Sep 7, 2003 | 07:03 PM
billrigsby's Avatar
billrigsby
OPEN or LS ?
How would you tell the differance between OPEN and LS
diffs, with no tag and the possibility the rear end has been
changed, take the cover off and look for what?
Bill
Old Sep 7, 2003 | 07:07 PM
Supercab's Avatar
Supercab
Cool OPEN or LS ?
The way I've always check is to jack up the rear and spin the wheels, and look to see if they both go the same way and if they do its LS, and if they go in oposite direction its open.
Old Sep 7, 2003 | 07:30 PM
Bikerider900's Avatar
Bikerider900
OPEN or LS ?
What's the real difference?
I think I know but I'm not real sure...
Old Sep 7, 2003 | 09:25 PM
Manwith3fords's Avatar
Manwith3fords
OPEN or LS ?
LS is about a 50% positrac, thats why its called a Limited slip. My 1995 Cougar XR-7 has a LS 8.8, if I apply the brakes with light pressure for a brake burn, it will smoke both wheels. If I apply heavy brake pressure, it will only smoke the drive wheel.
Old Sep 8, 2003 | 04:11 PM
Bikerider900
OPEN or LS ?
Just figured out that mine is a 3.55 LS rear end behind a C6 auto.
Old Sep 8, 2003 | 06:56 PM
billrigsby's Avatar
billrigsby
OPEN or LS ?
Thanks, Then if it turns out to be a LS.....
Then I figure there will be an additive when changing
gear oil, is this only from FORD or is it available aftermarket?
Best one to use, etc.
Bill
Old Sep 13, 2003 | 06:15 PM
93EddieB's Avatar
93EddieB
OPEN or LS ?
there is not always a friction additive needed for limited slip. there are mechanical l/s too. auburn makes one. it depends on if yours has clutches or is mechanical.
you can buy gear oil with the additive in it or buy it seperately at the parts store.
