Engine swap opinion
Old Aug 14, 2017 | 04:26 PM
Eric1976mi's Avatar
Eric1976mi
Engine swap opinion
My engine in my 64 f250 2wd is dead and I found a 1984 f150 4x4 with a 351w/c4 with under 80k. It's drivable and shift's smooth. Can I use this in my truck? I'm unsure if the transfer case complicates things.
Old Aug 14, 2017 | 05:17 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1984 F150 351W will have a C6, not a C4.
Old Aug 14, 2017 | 06:54 PM
Eric1976mi's Avatar
Eric1976mi
I meant that.,too much texting back and forth. The 4x4 trans won't work with my 2wd anyways. I found a couple c4 transmissions for sale near me I just need to find a motor. I have to move fast because I only have ascess to this garage with a lift for about a month.
Old Aug 14, 2017 | 09:13 PM
hello113's Avatar
hello113
motor mounts will be a problem but if u have time put a cv front suspension in it and the motor mounts will be easy to get you can make the trany mount your self but 1 month will be a chore
Old Aug 15, 2017 | 08:19 PM
F-ONE's Avatar
F-ONE
B. S.!!! Aftermarket small block ford crossmember and side mounts..at least 3 different types are available from all the usual suspects. The Crown Vic is not the answer to everything especially a F 250.
Old Aug 15, 2017 | 08:55 PM
hello113's Avatar
hello113
yep I am wrong I didn't catch the f250 sorry the cv would be just wrong
big-ugly
Feb 20, 2011 09:45 AM
bc-hillbilly
May 1, 2008 07:03 PM
scottko4
Apr 30, 2007 04:50 PM
jas2187
Engine Swaps
Nov 22, 2004 02:18 PM
