Code 2074 issues
Old Aug 13, 2017 | 09:16 AM
zekestr's Avatar
zekestr
Code 2074 issues
2012 F250 Superduty Lariat, 6.7 L.
While driving the cold air filter came loose and threw a CEL, code 2074. Corrected that issue, but CEL came back. Codes of 2074 and 2074pd. Cleaned both MAP and MAF and codes came back. Replaced both MAP and MAF and codes came back after about 20 miles. Any thoughts on next steps? Your help is much appreciated.
Old Aug 13, 2017 | 03:06 PM
cappa's Avatar
cappa
What intake are you using? Reason I ask is some of the bigger intakes, like the nl stage 2, are bigger diameter than the stock intake. This means you need a tune specific to the larger intake as the air flows slower in a larger diameter pipe. The maf needs to be rescaled in the tune.
Old May 8, 2021 | 11:08 AM
Sailor#10's Avatar
Sailor#10
Got a P 2074 code on my 2017 after 85,000 miles. Took it to the dealer and they confirmed that there is a Technical Service Bulletin (TSB) to correct this code for all 6.7s built before 2019. Cost me $90 for the analysis and reprogramming. Problem went away. TSB is 19-2343. It reprograms the PCM and resets the MAF sensor.
Old May 8, 2021 | 04:28 PM
The Bone's Avatar
The Bone
Did you replace the CAC pipe with one from Ford or did you get a aftermarket one? How many miles on the new CAC pipe? It could be you have a air leak somewhere. I would look closely at the hose clamps and the connection on the big end.
Old May 9, 2021 | 09:29 AM
dirthawg's Avatar
dirthawg
Bone - OP is a one post wonder. He joined the same day this thread was created in 2017 and hasn't returned since.
Old May 10, 2021 | 09:01 AM
The Bone's Avatar
The Bone
Caught me again LOL. I need to read the date on these threads
srgpelayo
1997 - 2003 F150
Mar 23, 2011 10:02 PM
boogaloo
1978 - 1996 Big Bronco
15
Mar 16, 2011 08:51 PM
is300wrx
2004 - 2008 F150
16
Dec 2, 2007 07:12 PM
Pltybx
1997 - 2003 F150
Jan 4, 2007 02:27 PM
