need some help choosing correct wheels
Going to be needing some new tires this fall and am thinking about getting new rims also. Currently I have 17" wheels and might go with some 18".
I'm looking at 295/70/18 tires on 18x9 wheels(specifically the gear 740b series)with a 3700lb rating and a +18 offset. How would this setup work on my stock '13 F250 4wd?
I want to fill the wheel wells up a bit more but don't want them too full that I get rubbing issues at full wheel lock and suspension compression. I also don't want the tires to stick out past the fenders much. I have the factory wheel flares so I have a bit of room to go out but I want the flares to cover everything.
Any other setups I should be looking at in terms or superduty rated wheels and different sizes?
Also, I would need some new TPMS sensors so I didn't have to take apart my OEM wheels so which one's would I need to go with?
mothy
10-25-2016 01:51 AM
