Carb going dry while driving. Why?
Old Aug 14, 2017 | 12:46 PM
TeachNlive4ever's Avatar
TeachNlive4ever
Your running the eddy carb. Wes's T/A with the eddy is doing almost the same, but different. I can roll at 100mph as long as I want. As soon as I let off the gas and hit it again, it acts like there's no fuel. Pat the gas a couple of time and that thing backfired so damn loud I thought the back end blew off.
All that to say, I did read that the floats will "move" out of adjustment.
I also have a buddy that has to run an electric fuel pump for the same reason you speak of and we have gone tip to tail trying to figure it out, but it will absolutely not run on the mechanical pump.
Old Aug 14, 2017 | 01:26 PM
351Cleveland C4's Avatar
351Cleveland C4
Originally Posted by ultraranger
A 5/16" diameter fuel supply line should easily support 450+ hp. Unless you're making more horsepower than this, probably won't help going to 3/8" diameter line. The problem likely lies somewhere else in the system.
That's correct. And with 7psi of pressure, it should be plenty.
Old Aug 14, 2017 | 01:44 PM
JEFFFAFA's Avatar
JEFFFAFA
Agreed that 5/16" can support more than we have. With 3/8" there would be more fuel in it at any given spot to absorb the heat. The more fuel being feed the same amount of heat won't get as hot as a smaller amount of fuel. And plus if Garrett hand makes one it would prolly have smoother bends. Back in the day I was told heat soak usually happens in the bend of the fuel line.
Garrett, you could try some rubber hose around your existing 5/16" and checking the float level as Teach suggests.
Old Aug 14, 2017 | 01:57 PM
351Cleveland C4
I will probably look at bending a new line from pump to carb. Being careful about how it's routed. And wrap it in insulation as well.
I also ordered a new thermostat from TMeyer inc. 180*. He's the only one that makes a PROPER Cleveland thermostat. So that should help keep things a little cooler as well.
Old Aug 14, 2017 | 02:40 PM
Brian1971f100's Avatar
Brian1971f100
I think changing the line that are rubber over to steel braided line would help if the line is collapsing from being too hot. The other alternative is an electric fuel pump located at the end of the first hard line as it exits the cab.
Old Aug 17, 2017 | 11:42 AM
351Cleveland C4
Teach, here's the thread.
Old Aug 17, 2017 | 01:00 PM
JEFFFAFA's Avatar
JEFFFAFA
To bad you couldn't make it going to Tombstone Garrett. Sorry for the short notice. I had a blast meeting Teach and his wife there.
Old Aug 17, 2017 | 01:47 PM
351Cleveland C4
I really wanted to go but I just had too much to do that day that couldn't wait. Hopefully next time!
Old Aug 18, 2017 | 07:26 AM
TeachNlive4ever
The King and I decided it would be a bad idea for us to live close to each other. Left unsupervised, we would get in trouble.
Old Aug 18, 2017 | 08:40 AM
orich's Avatar
orich
Cool
I've found that getting in trouble gives you something to talk about when you get older.
Orich
Old Aug 18, 2017 | 08:43 AM
orich's Avatar
orich
delete double post
Old Aug 18, 2017 | 11:36 AM
351Cleveland C4
Orich
Nobody ever remembers the time that everything goes as planned!
Old Aug 18, 2017 | 12:53 PM
  #28
TeachNlive4ever
Only because there's too much involved....
Old Aug 18, 2017 | 01:13 PM
  #29
JEFFFAFA's Avatar
JEFFFAFA
"The best laid plans of Mice and Men".
Old Sep 3, 2017 | 02:02 PM
  #30
351Cleveland C4
Well, the cooler thermostat surely helped. I drove yesterday pushing it harder than I ever have for quite awhile. 75-80-85-90-95 mph for 40+ miles. TOWING A small 1200 pound trailer...
It ran fine until going up one hill when I downshifted and really gave her hell. But it never actually died on me.
