Idle fluctuation when up to temp?
Old Aug 11, 2017 | 03:47 PM
z31freakify's Avatar
z31freakify
OK as you all know I rebuild the Mules engine on my sig about a month ago everything is working perfect and as it should but I have fluctuations at idle and only at idle when truck is up to temp between 650 600 rpm it fluctuates, my PCM ain't updated to work with OBDll so diagnostics is kind of hard to figure out. Only thing I've checked so far is fuel pressurewith a mechanical gauge I'm at 65 psi at idle and 55psi @ WOT under load, IPR looked almost new didn't bother replacing the o rings, ICP connector is bone dry, fuel filter looks brand new after the 2500 miles I've put on the rebuild. Anything missing or that I should check? All input is welcome.
Old Aug 11, 2017 | 03:54 PM
z31freakify
I forgot to mention that I'm out of an oil pressure gauge, I quit my job two weeks ago and all "my" home made tools stayed in the shop
Old Aug 12, 2017 | 08:35 AM
nossliw's Avatar
nossliw
I'd lean towards your ipr.
Old Aug 12, 2017 | 11:07 AM
97-psd's Avatar
97-psd
Agreed.
The IPR really shows itself when the oil is warm
Old Aug 12, 2017 | 11:13 AM
z31freakify
Sweet thanks guys I'll check it out as soon as I can.
Old Aug 12, 2017 | 04:14 PM
97-psd's Avatar
97-psd
At least the o ring replacement is pretty easy and cheap
KIDkiser
Mar 20, 2015 12:31 PM
Tugly
Feb 12, 2014 04:37 PM
08F550
6.4L Power Stroke Diesel
Dec 31, 2013 04:52 PM
cowmilker08
Aug 19, 2011 04:54 PM
brainfart
1983 - 2012 Ranger & B-Series
Mar 11, 2006 01:19 PM
