Replacing 223 Intake/Exhaust Manifold Gaskets
Old 06-19-2017, 11:45 AM
Wolfracing's Avatar
Wolfracing
Wolfracing is offline
223 I/E gaskets replaced -Problem Persists=Updated
What is the process? Should they be taken apart from each other under the carb or leave that be? Leave the exhaust attached or risk taking it off and stud breakage? Is there a torque spec and pattern?
Any tricks I should be aware of?
Last edited by Wolfracing; 08-03-2017 at 05:43 AM. Reason: Overall subject has changed
Old 06-19-2017, 04:15 PM
matthewq4b's Avatar
matthewq4b
matthewq4b is offline
See below pages from the shop manual
Old 06-19-2017, 04:57 PM
Wolfracing's Avatar
Wolfracing
Can't ask for any better than that!
Thx
Old 06-19-2017, 06:00 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
There's one thing misleading in the intake manifold pic, it appears to only shows one carburetor base gasket.
But if you look closely at the inside, there are 6 total of: B6A-9447-B
Old 06-23-2017, 11:51 PM
Wolfracing's Avatar
Wolfracing
What is the purpose of the six? Mine as found and currently only had one. Does it affect how it runs?
Old 06-24-2017, 02:33 AM
matthewq4b's Avatar
matthewq4b
To insulate the carb from exhaust manifold heat.
Old 08-01-2017, 09:07 PM
Wolfracing's Avatar
Wolfracing
Ok I have it disassembled. And now questions.
First, there was no gasket between the intake and exhaust at the heat riser chamber. The gasket kit came with a gasket, that doesn't fit. It's kind of the right shape, but too large/long. Three bolts fit, but the gasket hangs over and there is an extra bolt hole in it. Do I need a gasket there at all?
Second, the gasket kit came with a modern gasket. Do I still need the rings, or are those no longer used with the new style gasket? Are the torque specs the same with the modern style gasket?
Old 08-02-2017, 05:50 AM
Wolfracing's Avatar
Wolfracing
Anyone with help?
Old 08-02-2017, 01:14 PM
Wolfracing's Avatar
Wolfracing
Someone knows! Please speak up!
Old 08-02-2017, 01:28 PM
DriverReturnedOnFoot's Avatar
DriverReturnedOnFoot is offline
I just replaced my intake and exhaust gaskets as I was installing a rebuilt head. Mine too had no gasket between the two and I did not install a gasket going back together. I have started mine since and have seen no issue yet.
Not to confuse you, but what "rings" are you speaking of? Did they go on the intake and exhaust manifold before?
Old 08-02-2017, 01:40 PM
Wolfracing's Avatar
Wolfracing
There was no gasket material at the exhaust or intake flanges, but the intake had rings that were into the port a little ways on the head side and flanged out on the intake side for a sealing surface. They all fell out when I pulled the intake. I guess I can leave them on the ground?
Oh I like the screen name!
Old 08-02-2017, 01:44 PM
Hmmm. There is more experience here on this forum that can give you more advice. I would throw them away but I am probably wrong. I don't remember seeing any on mine.
Thank you sir. I am definitely from a Ford family.
Old 08-02-2017, 01:55 PM
Wolfracing's Avatar
Wolfracing
Thanks for weighing in. That's what I will do.
Old 08-02-2017, 02:17 PM
No problem.
Please let us know the results.
Old 08-02-2017, 03:46 PM
Wolfracing's Avatar
Wolfracing
I will. Fingers crossed that I can get this thing running correctly!
Quick Reply: Replacing 223 Intake/Exhaust Manifold Gaskets
