MBRP 4" PLM exhaust on Excursion
Old Aug 8, 2017 | 11:06 PM
David Unruh's Avatar
David Unruh
Wanting to run a straight pipe exhaust on my 2004 6.0L Excursion. Would the MBRP PLM Series 4" Turbo Back Exhaust fit around the rear gas tank, etc.? Thanks for the information
MBRP PLM Series 4" Turbo Back Off Road Single No Muffler Exhaust -
Old Aug 9, 2017 | 12:04 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
If you currently have the stock exhaust, I'd do a downpipe back or cat back exhaust.
When I got a full 4 inch Flo-Pro system, I lost low end power on my truck stock and tuned (hot too). No matter who's tunes I ran and/or how hot I tuned the FICM (Econo, Atlas 40, Atlas 80) the bottom end spool suffered along with my fuel economy.
After talking to the engineer who wrote the software these trucks run on, he mentioned that unless I plan on racing my 6.0, the best option for spoiling was the stock downpipe and exhaust.
To that end, I bought a diamond eye 3.5 inch downpipe and installed it. As soon as I did, my turbo spooled night and day better and over s few tanks of fuel, my fuel economy recovered nicely. Turns out he was right on the money
There are also fitting issues with the 4 inch down pipe. The stock and even 3.5 inch downpipe fit much better.
Old Aug 9, 2017 | 12:08 AM
SmackDaddy's Avatar
SmackDaddy
I run a 3.5" DP with straight 4" exhaust and it fits nicely.
Old Aug 9, 2017 | 10:13 AM
David Unruh
Thanks for all the information. Any suggestions on cat back exhausts?
Old Aug 9, 2017 | 07:58 PM
Toreador_Diesel
Diamond eye does but you'd have to check a few FTE vendors. Exhaust companies make more money on full systems than they do the cat back systems so they tend to push the full systems more than anything else.
Diamond eye also makes a turbo back system with a 3.5 inch downpipe
Old Aug 10, 2017 | 04:36 PM
David Unruh
Bought the Diamond Eye Exhaust. Thanks for the information. It is coming in the mail from Thorough Bred Diesel tomorrow. Will update once it is installed
Old Aug 10, 2017 | 07:38 PM
Per4mance's Avatar
Per4mance
I like mine, sounds nice too.
Old Aug 11, 2017 | 01:00 AM
David Unruh
Will running the diamond eye exhaust without a tuner throw any codes?
Old Aug 11, 2017 | 01:49 AM
Mike189677's Avatar
Mike189677
There are no sensors in your exhaust that could cause a check engine light. Your pcm will be none the wiser.
Old Aug 13, 2017 | 11:44 AM
David Unruh
Final Question. Bought the 4" straight pipe turbo back exhaust from diamond eye. Looking to delete the cat as the system calls for reinstalling the old stock one. Where can I buy a replacement? Because it asks for the stock cat I should be able to get a cat delete for the stock exhaust, correct?
Old Aug 13, 2017 | 02:48 PM
Toreador_Diesel
4 inch down pipe and all?
Old Aug 13, 2017 | 03:35 PM
David Unruh
3.5 inch downpipe
Old Aug 13, 2017 | 03:56 PM
Toreador_Diesel
Seeing as you have a diamond eye exhaust, they make a cat delete pipe that goes with their kit. My exhaust ended up as a 3.5 inch until it was past the passenger side front door. From there it's 4 inch back.
If I had my truck, I'd take a picture of it for you, but it's sitting at one of the laziest transmission shops I've ever seen.
Old Aug 13, 2017 | 05:49 PM
David Unruh
I saw that they had that, it doesn't look like it fits for my kit (K4352A-RP) they also sell a cat delete pipe for the stock system and it (my kit) says that it's designed to have the stock cat reinstalled.
Old Aug 13, 2017 | 07:57 PM
tfunk88's Avatar
tfunk88
yep, get a cat delete pipe and you'll be good...and you'll love the sound of the exhaust now. It's awesome
