driveshaft- one pc vs twp pc
Old Aug 8, 2017 | 06:16 PM
emeraldcoupe's Avatar
emeraldcoupe
so i'm going to be swapping a 302 / 4r70w in place of my 360 / c6. first truck I've had with a two piece. since i'll need a different length shaft for the swap, is there any reason not to swap to a one piece shaft?
Old Aug 8, 2017 | 06:41 PM
smoky_diesel's Avatar
smoky_diesel
what is yolk style of 4r70w? fixed or slip?
Old Aug 8, 2017 | 08:15 PM
emeraldcoupe
slip yolk , it's a mustang trans
Old Aug 8, 2017 | 08:26 PM
raytasch's Avatar
raytasch
Believe Nothing
A given length driveshaft can only run at a certain speed without setting up damaging vibrations. This is one reason why some vehicles run two piece driveshafts. There are several sites that discuss this. I believe this site will cover the basics.
Driveshaft Safe Operating RPM Calculator | Spicer Parts
Another: http://www.dennysdriveshaft.com/pote...alculator.html
And yet another: http://www.hotrod.com/articles/ccrp-...alancing-tips/
Old Aug 8, 2017 | 08:30 PM
fe390pc's Avatar
fe390pc
Really depends on the length. If it's too long they tend to vibrate, that's why the original was a two piece.
Old Aug 8, 2017 | 10:11 PM
emeraldcoupe
thanks, i'll check out those links.
Old Aug 9, 2017 | 12:25 AM
HIO Silver's Avatar
HIO Silver
The longer the driveshaft the larger OD n thicker wall thickness it has to be to eliminate deflection or "whipping".
it can also result in loss of ground clearance.
Old Aug 9, 2017 | 07:04 AM
ultraranger's Avatar
ultraranger
The bending (whipping) of the driveshaft is known as the critical speed rating of the shaft. Everything has a natural frequency. If the shaft reaches its own resonant frequency, it will self-destruct.
Driveshaft Critical Speed
Old Aug 9, 2017 | 08:00 AM
HIO Silver's Avatar
HIO Silver
AKA "harmonic" frequency.
Old Aug 9, 2017 | 08:53 AM
ultraranger
Critical speed of the shaft is more of a concern with an overdrive, when in overdrive, since the driveshaft will be spinning faster than the engine and faster than what it would be turning if a (non-overdriven) transmission was simply 1:1 in high gear.
Old Aug 9, 2017 | 05:03 PM
JEFFFAFA's Avatar
JEFFFAFA
AHA! A couple years ago the carrier bearing in my 2 piece driveshaft was shot. 2003 Harley F150. Supercharged and overdrive A/T. Originally 6# of boost from the Factory. Now 12#. Ford nor aftermarket listed a separate carrier bearing. So I had it sent out to a driveshaft repair company. They gave me the choice of them machining to make one fit or a one piece shaft. They pushed more for the one piece. I said no. Fix the two piece. I figured there had to be a reason why Ford went 2 piece. And now I know why!
Thanks guys.
Old Aug 9, 2017 | 05:24 PM
FECruzer69's Avatar
FECruzer69
If you're driving at the same road speed, say 60 mph, your driveshaft won't be spinning any faster with overdrive. If you have, let's say a 3.54:1 diff gear, your driveshaft will turn at the speed of the diff ratio (3.54 turns for every one). The engine rpm is what would change, with overdrive the engine would run slower.
Old Aug 9, 2017 | 07:44 PM
ultraranger
If the output shaft of the transmission (and thus the driveshaft) was turning slower, then this would be known as an underdrive.
See explanation of what makes an under/overdrive.
Overdrive: What Does This Mean? | Gowesty
Old Aug 9, 2017 | 09:44 PM
FECruzer69's Avatar
FECruzer69
Well, I'm not sure if we're on the same page, but I'm assuming that the comparison is being made at the same road speed with the same diameter tires and the same differential gear ratio. If the road speed is the same and the tire size hasn't changed and the gear ratio of the diff hasn't been changed, then the driveshaft speed cannot change. It doesn't matter whether the transmission has overdrive or not. The only thing that would be different would be the engine rpm.
Now, if we are not doing the comparison at the same road speed then all bets are off. For example, if the engine were driven in high gear at the same engine speed, lets say 2500 rpm, and the tire size and final drive ratios were equal in both trucks, then the truck with overdrive would have a driveshaft spinning faster than the truck without overdrive. The truck with overdrive would also be traveling at a higher speed.
Old Aug 9, 2017 | 10:49 PM
spdcat72's Avatar
spdcat72
FEcruzr69 is correct. Driveshaft speed is determined by rear gear ratio, tire diameter, and road speed. Unaffected by transmission. It could not even have a transmission, and the rearend pinion would turn the same speed at the same road speed,.
